Question about Bosch Axxis+ WFR 2460 Front Load Washer
My Axxis wfr 2460 is not releasing the fabric softner from the drawer
The wfr 2460 is 5 years old and is a great machine but lately it has not been dispensing the fabric softner. My first though is that the dispensor cover is clogged with fabric softner (it is very moldy) but I could be wrong here. If I were to clean it I don't know how to get the cover off. I have tried to remove the 3 screws but the dispensing housing is secure by what appears to be the top mounting rail. I thought I read on a similar site that I should check out a sensor but which one? Thanks for you help in advance.
  • DIY_Dad Dec 01, 2007
    I have taken a tooth brush to the top of the dispenser cover before and this has helped. I will check to see if I see water flowing into the drawer during the final rinse cycle. Is there a better or easier way to clean the dispenser cover? I was thinking that if I could remove it I could clean it.
    President:
  • 1,294 Answers
You could try a tooth-brush. And after you fill your quantity of softener, top it with water till the exit level of the compartment. You could also check whether water actually pours into the compartment during the final rinsing of the clothes; in this case you should check the inlet pipe screens of your inlet pipe into the machine; which can be done without opening up the machine.
Posted on Dec 01, 2007
  • prem mathew Dec 01, 2007
    You can peep into the compartment by opening it a little during the water flow during the softener flow.
    And dont forget to rate me pl.....whatever.
    You can remove the dispenser to clean, but you should figure this out; maybe refer to your manual?
There are 3 compartments . . .
It says the 1st compartment going left to right laundry detergant and stain remover, the middle is for the soaking agent, and the last one is for fabric softner. I hope that helps!
You can download the manual online and I found the info on page 12 of the manual.
Mar 02, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Door handle is loose and door can't be openBosh washer WFR 2460
    Remove the top cover, and release the door catch from inside the front of washer.
    Please rate my solution.
    Thanks.
    Oct 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
    Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
    hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
    Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
    Kenmore 44082 washer won't take in fabric softener
    Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
    Jan 17, 2009 | Kenmore 44102 Front Load Washer
    WFR 2460 Front loader
    We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
    Jun 27, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
    Display field
    Not sure if the 2450 is compatible with the 2460, but here is a parts diagram that shows the display module, part #AP3854652, for $97.69 from AppliancePartsPros.com. I ordered replacement carbon brushes and a drain pump from them and have been happy with their service.
    Mar 12, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
    Frigidare Front Load Washer dispenser drawer wont drain.
    I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
    Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
    Bosch Axxis+ WFR 2460 Front Load Washer Logo
    124 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Carmen Mikulic
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
