I have GE side by side profile refrigerator Model # PSS26MSTCSS.
The door flap for ice dispensor does not close tight. IT is little wared at the edges, so there is leakage of cold air. This causes the frost and ice inside the dispensor.
I think I need to replace the flap. Where can I get the flap door?
Can it be done easily?
Thank you .
the number for ge parts service is 1-877-959-8688. make sure you have the model # and serial number. if you don't have a manuel or if you have one that covers more than one model in it than you have to look for a little black most likely silver plate wich will have that info on it. if it's not on the inside or front of fridge anywhere you will have to pull it out from the wall because it will be on the back of it. hope i helped you.
Was this helpful?
Yes
No
Popular Solutions for GE Monogram® ZISS420DMSS
GE Monogram® ZISS420DMSS Side by Side Refrigerator
The problem is the ice maker fails to make ice. I noted the green light was blinking so I shut it...
(More)
The problem is the ice maker fails to make ice. I noted the green light was blinking so I shut it off for a few hours and turned it back on. The light is now solid but not making ice. I am unable to find the model in the manual, although it is a 48" side by side.
Both sides of the refrigerator will just shut off for no reason. I had a new computer installed and...
(More)
Both sides of the refrigerator will just shut off for no reason. I had a new computer installed and once again found it off. No lights on the door, no power at all.
The CCD does not control temp - fan kicks on but temp only goes down - ultimately freezes everything...
(More)
The CCD does not control temp - fan kicks on but temp only goes down - ultimately freezes everything along with the water dispenser.
I have a built-in monogram series side-by-side refrigerator 36x42x48 bought in 2002. About every...
(More)
I have a built-in monogram series side-by-side refrigerator 36x42x48 bought in 2002. About every half hour or so it makes a noise that sounds like a machine gun about 10 rapid tat-tat-tat sounds to the left side in the freezer area. I have removed the ice maker aparatus turned the ice maker off and pulled the plug apart inside the ice maker area and it still makes the sound. A GE repairman has come out but doesn't know what is wrong. Any ideas? Jim McNelis
