Question about LG HBM 730 Bluetooth Headset Wireless Headset
My LG HBM-730 won't turn on!
I already made sure it was charged. In fact, the light came on while I was charging it, and then shut-off after the charge was complete, just like it always has. But now when I try to turn it on I get nothing. No sound, no light, nothing. Is there a way to fix this, or am I just SOL? It's still under warranty so that's a good thing...
Thanks in advance,
Emma
  • Anonymous Jan 09, 2008
    I am having the exact same problem.
SOURCE:
SOURCE: LG HBM-730 disconnect problem
I have the LG HBM 730 headset also. Have the same problem with the LG VX 8700 phone. I got a replacement headset and the problem remains. I was told to delete and re pair the connection. I did so to no avail. I was told to pair at 10 -15 feet. I did so to no avail. I just went out and bought a $15. wired headset out of simple frustration. I also believe it is a buggy set.
Posted on Sep 05, 2007
SOURCE: Won't charge?!
You must hold the poer button down until you see the light blink 4 times and then it is turned on.
Posted on Jan 16, 2008
SOURCE: LG HBM-730 Won't Connect to Treo 650
Actually it's a Treo 680. Finally took the battery out of the phone. That seemed to clear everything so that I pair the bluetooth with no problem.
Posted on Feb 23, 2008
SOURCE: i don't know the pin number to my bluetooth HBM-730
jst put 12345 or 0000
Posted on Jan 17, 2009
rockfixya
  • 679 Answers
SOURCE: How do I set my Bluetooth Headset HBM-730 to discover mode?
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HBM-730 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
My HBS 730 LG Stereo Bluetooth head set doesn't seem to come on. It seems not to charge up according to its indicator light.
the rechargeable battery has died and usually not serviceable by the consumer .check with a phone store .
Dec 08, 2015 | LG HBM 730 Bluetooth Headset Wireless...
What AC charger can I use with my LG HBM 210 Bluetooth?
It is better to use the recommended charge from LG than to try one which is a universal type as the battery charging specifications are very critical to overcharge.
Sep 24, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
It's been a while since I've used thiss LB HBM 730 bluethooth wireless headset. How do I turn it on to sync it?
Here's the link to the instructions.
http://www.megaaccy.com/HBM_730.pdf
This should get you started. Since you haven't used it for some time, make sure you charge the battery for 24 hours before using it.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
My LG HBM-210 doesn't seem to charge as the charging LED indicator just flickers on and back off.
Hi decross 903 Did you find a solution....I have the same problem? I plug it in to charge, the light comes on temporarily and then off. I have no idea if it is charging or not.
Dec 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Not connecting
i was having a problem getting my hbm-730 to connect/turn on with my enV. i took the suggestion of turning phone off and then turning it back on. i had already removed the device from my phone thinking i had to reprogram it.
when i turned the phone back on, i was able to pair up my bluetooth with my phone with no problem. now, we'll see what happens next time.....but that worked for now.
Dec 24, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Won't charge?!
Dec 01, 2007 | LG HBM 730 Bluetooth Headset Wireless...
My phone wont locate my LG bluetooth.
Just because your phones Bluetooth option is turned to on doesn't mean it's searching. I would try going in to your device history and clicking on new device while your Bluetooth is in pairing mode.
Aug 08, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
297 people viewed this question
Top LG Radio Communications Experts
B.Th. Pluijm
B.Th. Pluijm
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
