I went to Dremel.com and found a parts explosion for this tool and the shunt appears to be connected to the brush holder. It is a little fuzzy on the print. If you go to their site they have a toll free number that you can talk with a tech and they will be glad to help. If I have helped you with the problem would you please rate this response accordingly and thank you.
When I switch the laser level on it won't automatically level itself and travels through the...
(More)
When I switch the laser level on it won't automatically level itself and travels through the "y" axis and gives the out of level alarm. I don't have an operating manual and don't know what the problem is.
Battery's will not charge. Power at outlet is normal and charger is putting out 3.6 volts. I believe...
(More)
Battery's will not charge. Power at outlet is normal and charger is putting out 3.6 volts. I believe the battery'sare bad. Where can I get replacemant battery's?
I have two Spin-saw,s that need repaired to the flex-shafts iner cable is broke S.S no.54-8205-8 and...
(More)
I have two Spin-saw,s that need repaired to the flex-shafts iner cable is broke S.S no.54-8205-8 and Spin-saw No. 54-8204-0 also inerfex-shaft cable is broke both need repaired or new flex-shafts for both units
