Question about SanDisk Sansa e250 MP3 Player
U-mp3-1 my u-mp3-1 is frozen but the power button is not the one that you can press down. It's the one that slides. What can I do?
  • Anonymous Dec 09, 2007
    can't copy file from CPU ( not have driver )
    RX : 8880525
  • 8,596 Answers
Use volume + method:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Nokia 820 screen is frozen
Is the screen frozen on an app? If yes, have you tried to reboot the phone? If holding down the power button for 12 seconds doesn't bring up an option to 'slide down to power off', try pressing the volume down button and the power button at the same time, and hold them for 12 seconds. If that doesn't reboot the phone, you should be able to remove the back and take the battery out, count to 12, and replace the battery to reboot it.
Jul 27, 2016 | Nokia Cell Phones
Tip
How To Reboot An iPod Touch
If Your iPod Isn't Frozen
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
If Your iPod Is Frozen
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
on Jul 12, 2010 | Audio Players & Recorders
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Oct 30, 2014 | Apple iPad 64 GB WiFi
I Pad is Frozen in a games app
Usually a reboot will fix this problem. Press and hold the power button (rectangular button on the side) until you get a "Slide to power off message". Then just slide the slider to power off and you will see a spinning wheel. When the spinning wheel disappears and the screen is totally black the you just need to restart the iPad by pressing and holding the power button until you see a silver Apple.
Jan 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My visual land tablet is frozen on the lock screen, it want slide to unlock the screen, what should I do
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
  • 2 Turn the Tablet back on to determine if it is still frozen.
  • 3
    Remove the power adapter or USB cable from the Tablet. Turn it back off. Turn the Tablet over and remove the screw from the back of the device. Slide the battery panel off of the Tablet and pull the battery out of the unit.
  • 4
    Connect the Tablet to the power adapter and power it on. The freezing issue should be fixed and your Table should respond properly. Reinsert the battery and charge it to full before removing it from power.
  • Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
    Jul 29, 2013 | Tablets & eReaders
    How to unlock the key pad on a dell latitude D600 laptop
    Hi. Please do troubleshooting steps below:
    1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Ipod frozen
    Calm down and don't panic. Take the hold switch and slide it back and forth. Then, press the center circle button and the menu button untill you see a apple. Now your ipod mini will be fixed.
    May 10, 2010 | Apple iPod nano
    Frozennn
    Simply reset it. Hold down the "Sleep/Wake" button(on top) and the "Home" button(the one with the square on it) for about 10 seconds or until it says "Slide to power off," now slide the slider, then turn it back on by pressing the "Home" button or the "Sleep/Wake" button.
    Hope this helps!
    Sep 29, 2009 | Apple iPhone 3G
    How do you restart an Ipod?? I was trying to
    IF IPOD ISN'T FROZEN.
    IF IPOD IS FROZEN.
    3. Be patient.
    Hope this helps - good luck!
    Sep 17, 2009 | Apple iPod touch
    SanDisk Sansa e250 MP3 Player Logo
    116 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
