I have a Maytag Plus side-by-side refrigerator. Model number: MSD2756GEQ. Here's what's going on...- The refrigerator started getting warmer over the past few days and then the freezer also stopped being as cold as it should be.-The fan on the back is working, but the compressor is hot - not sure if that is normal or not.- There is a loud snapping noise that happens every few minutes and seems to come from the compressor area. Appreciate any help!
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Was this helpful?
Yes
No
Popular Solutions for Maytag MSD2758G Side by Side
water freezes as it comes into the ice maker causing water leak out the back of the fridge. What is...
(More)
water freezes as it comes into the ice maker causing water leak out the back of the fridge. What is causing this to freeze? We thawed the ice chunk out of the line with a hair dryer but it froze up again within 12 hours.
I have a MSD2758DRW Refrigerator. The coils are icing over about once a month for the last 2 months....
(More)
I have a MSD2758DRW Refrigerator. The coils are icing over about once a month for the last 2 months. From prior posts, it looks like the defroster is not working. 1) Is it possible for me to fix the problem or should I bring in a repair person to diagnosis the problem? 2) If it's suggested that I can fix the problem, what steps do I take to pinpoint the component? 3) Can you please include a link to a technical service manual? Thanks, Brad
Maytag msd2756dew just stopped with no warning. Had been cooling fine. Only problem had been refrig....
(More)
Maytag msd2756dew just stopped with no warning. Had been cooling fine. Only problem had been refrig. door not always sealing tight. Still no problems. In garage so ice machine not hooked up as no water source. Tried plugging into other sources, but won't come on. Help?
My refrigerator doesn't cool enough the refrigerator compartment but my freezer froze up the...
(More)
My refrigerator doesn't cool enough the refrigerator compartment but my freezer froze up the evaporator coil. What was the problem? The evap fan run too.
