Question about Motorola Mobility RAZR V3
Motorola razr v3 white screen problem
The big screen shows just a white screen and on the outside I just see a blue screen. on the key page the right side keys do not light up like the middle and left keys.
I gave this phone to my Dad, and somehow this happened, I tried charging it initially thinking the battery was dead, but the battery leaked and some red liquid was discharged. I cleaned it up and removed the battery and bought a new one, but haven't tried the new one. when I charge it or use my wife's mobile battery. Even before, I press the end button, the white screen shows up on the inside lcd and the blue on the outside and nothing happens, even when I keep holding the end key. I am a little hesitant using the new battery as I still have the choice of returning it.
Please let me know if a solution is possible. I wouldn't mind trying any idea. Thanks for the help in advance.
  • chckh1 Mar 13, 2008
    I have the V3m and have a white screen as well : (. Is it possible to get another and switch out mem cards? Thanks, Chuck
  • mabwiz Sep 27, 2008
    ithe same exact thing haddens to my red vorizon motorola razr so what store can i get a new battery and how much will it caust?
Try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Posted on Dec 01, 2007
SOURCE:
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
Motorola RAZR V3 with green screen
you can get in touch with motorolla for replacement or find one online .. the motorola razr is not sold through att anymore and is being discontinued through alot of carriers..good luck finding another one more of your options are goin to be online though .. motorolla's # is 800-331-6456
800-657-7576 (Windows Mobile Support)
Nov 18, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Pink razr phone lcd front screen problem
you need to change the LCD so take it to a mobile service center and have them replace the lcd for you.
Mar 13, 2008 | Motorola Mobility RAZR V3
White screen
tarheelfan,mtstreaks88 ...try changing the flex cable in the phone if that does not work, replace the LCD or Screen as you call it.
Dec 15, 2007 | Motorola Mobility RAZR V3
My Home Page Screen is White and My External Screen is Black
have the LCD replaced and the phone full service take it to a mobile service center close to you.
Sep 16, 2007 | Motorola Mobility RAZR V3
White Screen
change your settings
Aug 25, 2007 | Motorola Mobility RAZR V3
V3 razr goes to white screen
software problem u must contact service center and do flash it
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
167 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
