my dryer will not heat at all.Is this usually the heating element?I took the screws out of the back...
(More)
my dryer will not heat at all.Is this usually the heating element?I took the screws out of the back cover but how do you remove the cover?
Dryer will not dry clothes on first cycle. Dryer also turns on and off when the plug is moved, it...
(More)
Dryer will not dry clothes on first cycle. Dryer also turns on and off when the plug is moved, it seems there is a short in the plug or the outlet. Have cleaned out the lint trap and exit chute.
My Ge electric dryer, model dbxr463egww, will turn on and run for about 10 minutes and then kick...
(More)
My Ge electric dryer, model dbxr463egww, will turn on and run for about 10 minutes and then kick off. We can immediately restart it, and it will run for another 10 minutes. Doesn't matter which heat setting or timing option we select. Already tried cleaning it out with a shop vac no success. Any suggestions? My husband thinks it is the cyling thermostat??
