Question about Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX5115 printer
Shows OPEN HEAT ERROR and will not print. What causes this and how much is the replacement parts?
  • sachin gaiki May 12, 2008
    Open Heart Error
  • Anonymous May 25, 2009
    open heat error
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Posted on May 14, 2009
  • 1,113 Answers
Open heat error means that you fuser assembly has a problem and needs to be replaced cost will be 150-250 for the fuser
Posted on Dec 01, 2007
Printer is showing Open Heat Error & it is not getting solved
Open Heat Errors on the Samsung 4200 are caused by an interuption in powerflow thru the fuser unit. This is caused by one of two things. 1) The Power supply board is not putting out enough power to the fuser unit. 2) The fuser unit has a bad heat bulb or thermister. You can not really check these effectivly without having either replacements on hand or the full tech sheets and a multimeter. I am sorry to say buying a new printer or a replacement fuser unit will be your best bet.
Aug 30, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Open heat error comes on when I set up the machine. What can I do to fix I can print
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 02, 2010 | Samsung SCX 4521F All-In-One Laser Printer
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
My all in one is showing < open heat error > whe chage cartridge
Apr 30, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Engine Fuser Low Heat Error
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Samsung ML-3561N Laser Printer
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Failure to print
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
May 21, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Open heat error
when i on my scx-4216 samsung laser printer it show on screen open heat error on display screen
tell me the solution
Apr 17, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
1,309 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
