Windows xp professional sp2
When i am working on my computer at times it stops working and a blue screen comes up with the following message,
"Hardware malfunction.
call your vendor for support.
the system has halted."
please let me know what i can do myself to resolve the problem.
thanks
  • bonbonblok Jun 18, 2008
    We have a Shuttle XPC like this one and it hs been shutting down automatically continuously with an error to do with windows. Now the graphic card is not working properly and can't get the full extent from my grahics card and it can't find the drivers for the graphic card anymore. A computer friend of ours thinks its the motherboard. Could this be right?
Motherboard or hard drive problem. That is my guess..
Posted on Dec 01, 2007
SOURCE:
Error bigpipe win xp professional sp2
This is due to a security flaw in SP2. You will need to download SP3 update from Microsoft!
IF you go to Microsoft XP SP3 Manual Update, follow this link and download the update then run it. This will correct the issue.
I also suggest that turn on automatic updates. Although XP is no longer supported by Microsoft you will still get all the old updates.
Oct 16, 2013 | Microsoft Windows XP Pro W/MUI SP2...
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
How can i reprogram my computer
use blue screen viewer software to check where is the corruption.
or you can repair the windows using Windows disc...
Jul 30, 2012 | Microsoft Windows XP Professional SP2
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Microsoft Windows XP Professional
Sir my windows xp sp2 is not booting and shows stop 0x0000000e meassage with blue screen
You will need to boot it with the XP CD and perform a repair install if you have important data you need to recover. If boot with CD format it abd do a full reinstall. If you have any problems while doing this i would check the memory in the computer maybe by just checking 1 stick of ram at a time. Cheers from Scott and plz vote
Nov 02, 2010 | Microsoft Windows XP Professional With...
Blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
Problems for sp2
MICROSOFT STOPED SUPPORTING XP SP2 YOU SHOULD UPGRADE YOUR SYSTEM AND ALL YOUR SOFTWARES WILL WORKS
DONT FORGET TO RATE
Jun 08, 2010 | Microsoft Windows XP Professional With...
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Motherboard and cpu
thanks for the details supplied although I believe you're missing some details
1. are you trying to install the whole operating system (windows xp sp2) or only the SP2 for windows xp?
2. if you are trying to install the os (windows xp sp2) is this a clean installation (recommended) or you are trying to upgrade from a previous operating system (9x, nt, 2000)??
10. are you getting a blue screen with this message?? in what part of your installation??: the DRIVER_IRQL_NOT_LESS_OR_EQUAL or PAGE_FAULT_IN_NON PAGE_AREA message is something I'm assuming you're getting on a blue screen before the computer shuts down on you (please confirm if this is accurate)
2. if you answered yes to the previous question what we need is the line at the bottom portion of the blue screen where you see something like 0x000000?? (0x00000......
if possible get this information and post it here. this information is called a stop error (the blue screen is also called a stop error screen or blue screen of dead (BSOD) as is coloquially known) the code will give you/us a better idea of where the problem lies.. but taking an educated guess you may have driver problem creating some type of issues.
in the mean time my suggestions are the following:
a. while you get and post the information required above is, if you're trying to install the service pack 2 on a working xp installation, is to try to install the SP2 by only having the basic peripherials plugged into your system. (keyboard, mouse and obviously your monitor) and reattempt the sp2 installation.
b. if you're trying to install the operating system (either clean install or not) make sure your windows xp sp2 copy is a good copy (hopefully will be a valid copy of the os) if not you can always run into problems now or at a later time.
c. if you're trying to install the os and want to make sure your system/hardware configuration is appropiate for the installation this are your options:
1. check the HCL online (if you have a previous installation you are trying to upgrade to xp)
http://winqual.microsoft.com/HCL/Default.aspx?m=x
2. if you have a previous windows installation you can also use the upgrade tool to confirm if you have what you need to put windows xp on your system.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q307726
2. if you have don't have an internet connection you can use the windows xp cd that you have to confirm whether you have what it's required in terms of hardware:
Pop the cd into your CD drive. Close the screen if auto run launches and open Run from the Start Menu. Type in D:winnt32.exe /checkupgradeonly, substituting the drive letter of your CD-ROM for D if it’s different. This will launch the Microsoft Windows Upgrade Advisor that will identify any hardware and software upgrade incompatibilities.
Oct 07, 2008 | Computers & Internet
BSOD in windows XP Professional
A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
Jun 26, 2007 | Microsoft Windows XP Professional for PC
Open Questions:
Computers & Internet Logo
156 people viewed this question
Ekse
Alun Cox
