Question about Whirlpool GS6NBEXRL Side by Side Refrigerator
Right door handle upside down pinches fingers. how to remove and flip?
My right door handle I believe is installed upside down such that the curve at the apex is so close to the left handle, fingers get pinched. I would like to remove the handle, flip it right-side-up and see if that helps.
Q. Can the handles be flipped upside down? Note: I don't mean reversed from left to right. The left handle is fine.
I guess I can find out real fast if I someone could let me know the trick to getting the handle off. Thanks.
  • Mirellis Dec 01, 2007
    That was it!!
    No more finger pinches and the wife is way happy!
    Thanks a ton!
  • Anonymous Mar 29, 2014
    Door opens on the right vs left
    President:
  • 878 Answers
Mirellis, grab the handle with both hands and push in and up. The handle will slide off the retainer clips. To put them back on, line up the clip holes push in and pull down. I never tried flipping them, but you will find out real fast. This is for the GS6NBEXRL model that was posted, Catriver.
Posted on Dec 01, 2007
How to flip a door on hotpoint fzfm171
handle and hinges all removed to opes it side little plugs are in door and ref for this middle hing may bet turned upside down or pin removed to different hole if not handy call a service co. this is not easy all the time make sure all spacer washers are in same place when re installing take pictures as you take apart
Nov 06, 2014 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
How to remove sliding door inside panel of Mazda MPV
1. Work with slider in open position. It helps if you are on a slight incline so that door stays in fully-open position and won't slam shut on your fingers.
2. Remove inner handles and door panel:
a) Inner handle. Remove the inner handle first. You can't see it too easily but a wire clip about the same thickness as a large paper clip holds the handle to its shaft. It's shaped like an upside down "U" so it needs to be pushed straight up. Press the panel outward around the handle and you can just see the clip. Use a small thin screwdriver to locate the bottom tips of the clip and push it up. You may have to alternate from side to side but it will pop off. Grab it with a pair of needlenose pliers if you have to. The door handle willl now slide off - just pull it towards you.
b) Power window switch. Remove power window button by squeezing hidden tabs along the sides of the button. Again, you may have to push the panel outward a little and pry the switch to see the tabs. Wiggle it a little and the button will release. Pull it out and unplug the wiring harness.
c) Door panel. There are several plastic buttons which hold the panel on at the bottom and up the sides. Use a plastic putty knife to get behind panel and pop it out of the holes.
3. Once all trim fasteners are released, grab the door panel at the bottom and pull straight up to release it at the top. You may have to give it a quick upward tug to get it to release. Push the power window button wires through the mounting hole. Look at the panel buttons to make sure that all of them came off with the panel. If not, remove the remaining ones from the door and put them in their respective slots on the door panel. (Trying to re-attach the panel without the buttons installed on the panel will be frustrating.)
4. Outer handle removal.
a) Unclip the handle lock button / bar by turning the small tab and pulling the bar out of its slot. Hard to describe here but you'll figure it out once you see it.
b) Remove three bolts which hold the handle on the door. Note that one bolt is accessible from the outside of the door along the front jamb.
Replace handle and reverse the steps above.
Notes: Check the locking mechanism and make sure the door opens and closes before you reassemble the panel. Remember to orient the inner handle the right way before you re-attach its spring clip. (I've attached it upside down and it won't work!!!) . Also, be sure to feed the power window wiring harness back through the mounting hole before putting the panel back on.
Nov 06, 2012 | 2000 Mazda MPV
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
The driver's door will not close.
look at the door lock striker and compare it with the passenger door. I think you'll the black piece is stuck in the up position. If I'm corrct, all you need to do is to pull the outside door handle as if your going to open the door, at the same time using you finger or a screwdriver just flip the black latch (some go up, some go down, just compare the right front door ltach)
Jan 02, 2010 | 1999 Cadillac Catera
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Upside down
Yes there should be an easy answer..unless the valve assembly was sweated in upside down....there should be a plastic plate in the center of the handle...that allows access to the screw that holds the handle on (now if I remember right you have to have a MOEN tool (specialty tool ) to remove the valve stem and these seat in only one way...but I believe the handle can be rotated 180 degrees as the valve has a rectangular duplicate sided appearance unless this is something I have not seen ...and I used to work at an Apt community that had nothing but moen fixtures. Try flipping the handle assembly...and usually the chrome plates slip up over a sleeve some have 2 screws one on each side...if so take these out and invert the plate......I hoper this helps...good luck...please rate me....The Fang
Mar 26, 2009 | Home
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
MintCraft entry door lockset one will not stay locked ,
Try reversing or flipping them upside down.....If you put them on in the same day, Parts may have gotten Mixed up..... Try combining and Such as to make Things work....As long as you have all the parts that came with it...It should work.......Hope this helps.....Joe
Dec 30, 2008 | Hardware & Accessories
Not able to pull up the shower valve
The valve is in upside down. Sounds like the shower head runs all the time and thats what fills the tub? The valve needs to be flipped OR the diverter in the valve needs to be switched to the other side of the valve. If this is a one handled valve it is installed upside down. UP is indicated on the valve.
The valve can be reused just turned over.
Dec 13, 2008 | Moen 2919 Chateau Two Handle Tub and...
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
Whirlpool GS6NBEXRL Side by Side Refrigerator Logo
153 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
