Question about LG Flatron L1715S 17" LCD Monitor
No picture there is no picture the monitor goes to power save mode For reasons unknown Power Saving Mode will start- at times part way through a document or using the internet or during a game. I have checked the settings and they are on NEVER. The only way to restart is too use the off/on button to restart the computer. My monitor is a L1718S model - not the 15 model-
  • julluso Feb 15, 2009
    Hi guys:) i found a LG FLATRON L1715S in a container:)
    the power is working, but there is no picture on the screen!
    nothing shows up:( what can i do to fix this?
  • 6 Answers
It could be a simple cap problem on the control card. But, a 17"? That may not be worth the effort. Unless you have time and curiosity to look for a damaged component on the inner board. Since it does nothing screenwise it is probably something obvious if you open it up.
Good luck with your project. Maybe this will help. https://www.manualslib.com/manual/786974/Lg-Flatron-L1715s.html
Posted on Sep 26, 2017
  • 18 Answers
SOURCE: monitor flashes POWER SAVING MODE.. monitor dosnt turn on
A quick Google tells me this is a VGA analog interface monitor. Have you another monitor to test with, to see if the problem is the PC or the monitor. If another monitor works (esp. a CRT) your L1730s may still be fine. Set the refresh rate of the graphics adapter to 60HZ. then test your LCD again. Some monitors just blank the screen when they get a refresh rate they cannot handle. p.d.
Posted on Jan 14, 2007
  • 4 Answers
SOURCE: Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Posted on Jun 05, 2007
informatica
  • 1114 Answers
SOURCE: Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: http://us.lge.com/filedown.do?filepath=1000000757&fileName=L1750B-BF.pdf Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Posted on Jul 30, 2007
  • 38 Answers
SOURCE: "analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Posted on Oct 01, 2007
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Flatron L1719S
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1715S 17" LCD Monitor Logo
107 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
