Question about Dryers
Kenmore dryer my dryer will start and run about 30-60 seconds and then shut off. i checked the exhaust to see if it was clogged and it was not. can you give suggestions on whats wrong and how I can T-shoot down to the problem?
  • 1 more comment
  • Demeat Nov 30, 2007
    My dryer is a Kenmore model # 96283110 (Electric) any help would be much appreciated.,
    Thanks
  • christyf72 Jan 12, 2008
    Kenmore model 96283110 runs, but no heat
  • Anonymous May 15, 2009
    I have a Kenmoire Ultra Fabric Care dryer and it runs and will go the entire cycle, but it doesn't get hot. I checked the fuses and lint filters...and everyhting is ok. Any idea what it could be?
That happens to mine when i overload it and the clothes push against the door and open it imperceptibly -- but,evidently, just enough to shut it off.
Posted on Dec 30, 2007
Why does dryer start run a little beep 3 times cut off
Really you need to provide your model number. but that said... the number one cause of a dryer shutting down after a short warm-up is a blocked exhaust outlet. Dryers have a sensor that checks the exhaust temperature... if its not moving the hot air out side than it over heats and trips the sensor which will shut off the dryer for safety (no fires please!!). So check your exhaust outlet outside for lint blockage... check your exhaust hose/pipe for kinks where lint can build up and of course always check the lint screen for blockage.
Aug 05, 2014 | Kenmore Dryers
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
There is no heat
Check the exhaust vent tubing throughout. If clogged up with lint the sensor will shut the heating completely off all the time till cleaned
May 08, 2010 | Kenmore 62602 Electric Dryer
I have a large capacity Kenmore dryer that is not heating up what should I look for model #75201
A clogged exhaust vent tubing will collect lint causing the moister sensor to shut down the heat. Inspect & clean and it will operate again. If not the sensor is bad or the spark ignitor is at fault. The spark ignitor makes a clicking sound upon starting the dryer up within 20 seconds
May 01, 2010 | Dryers
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Dryer shut off while drying will not come back on
unit is over heating.... check venting for clogs, run unit without venting on and see if same problem happens, if not, theres a clog. clean venting also if you can check where it exhausts from the outside of the home. animals build nests there since its warm.
Feb 13, 2009 | Kenmore Dryers
Dryer is not drying clothes
chances are not na problem with dryer, runs for a bout a min and shuts off sounds normal for an empty dryer, the problem is probably where the exhaust leaves the roof, .roof vents have installed from factory a screen to prevent things from entering when not in use. problem is that screen clogs with moist lint and prevents proper air flow. go up and check that vent remove screen you should be fine
Mar 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Open Questions:
Dryers Logo
272 people viewed this question
Top Dryers Experts
Marvin
Marvin
