Question about HP LaserJet 2550n Printer
Hp laserjet 2550n not working
The orange exclamation button is blinking!
i bought it used, don't have the manual,
it won't print,
any ideas out there?
[email protected]
  • sujit566 Aug 26, 2008
    sir,
    i have a problem with hp colour laserjet 2550n printer while giving a print command it goes after a second it blink orange led.
  • mark795 Dec 25, 2008
    I have a 2550 that had not been used for a while. When I re-installed it this problem arose but I know the cartridges and drum are less than 20% through their life. I think HP have a software 'use by' date after when it automatically flags up as needing a cartridge change even when it doesn't.
    As the cost of the cartridges is more than a new printer, how do I override this at my risk?
  • HP Master
  • 1,113 Answers
  • Soulvisitor
    Soulvisitor Dec 01, 2007
    cartridge expired probally
SOURCE:
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Won't print!
Hi there, well I found a manual and online drivers for this unit. If you have never printed on this machine, and it is currently on the nwtwork? You have to either log into the printer or make sure the printer knows it is on the network. In the display it should state the IP address for the device. Also when you installed the drivers for the machine, I assume you did a successful "Test Page Print"? Let me know if you have more problems. Here are your links:
Manual & Drivers: Click Me
Turk
Oct 20, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
HP 2550n will not print
From the HP User's Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link to download the user guide:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00189910/c00189910.pdf
Oct 14, 2008 | HP LaserJet 2550n Printer
Amber light that is a triangle is blinking and printer will not print any suggestions as to what is wrong
if you press the orange(big main one) flashing button and it prints 1 page , the you have the paper size set wrong .....check your paper size settings , it comes as default letter , here in the uk we have to get the network guys to change the default to a4 ,
go to hp website and download the manual (the last one in user guide section )
HP PCL/PJL reference (PCL 5 Printer Language) - Technical Quick Reference Guide
here is the web page http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=uk&docIndexId=64902&taskId=101&prodTypeId=18972&prodSeriesId=388394
its has all the light codes there too .
Aug 21, 2008 | HP LaserJet 2550n Printer
Orange blinking light
hp colour laser jet 2550n while giving printing command it shows orange led blinking it dosen't print please help me.
Jul 24, 2008 | HP Color LaserJet 2550n printer + HP Color...
Are you using generic toners or HP branded? Try to reseat the yellow toner. The page counter can't be reset and should not be. This unit uses chips to recognize the toner level. Generic toners don't always have good chips on them.
Jul 09, 2008 | Office Equipment & Supplies
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 2550n Printer Logo
353 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
