Filter on indesit washing machine
I have an Indesit WM12X and there appears to be a lint filter on the bottom front right. How do I remove this and clean it? or is it not meant to be removed!
  • Anonymous Mar 18, 2014
    How do you clean filter on washing machine Indesit W1XXE127
    President:
  • 1,294 Answers
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
Where it filter drain?
It should be located at the bottom front right of washer, there may be a plastic cover across the bottom of the washer which you need to remove.
Unscrew the filter anti-clockwise to remove and clean.
Feb 23, 2011 | Indesit W 123 Front Load Washer
Indesit washing not completing cycle, washing very wet (ie not spinning) ny thoughts appreciated
Check the pump filter is not clogged up, this should be at bottom front right of washer, possibly behind a removeable cover.
If clean then it could be the brushes in the motor that need replacing.
Hope this helps.
Jan 16, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
Hi i have an indesit wd12x washing machine that does not drain the water. How do i get to the filter to clean it? Thanks
Your model of washer dryer is fittted with a self cleaning pump, and may not have a filter fitted.
To check if it has, remove lower plinth at bottom of m/c, and if there is a plastic panel there ,remove that as well.
If there is a filter fitted, you will see it at the bottom right front, it has a round cover, unscrew anti clockwise, remove and clean filter.
Pleas leave a fixya rating if you consider my solution appropiate to your query.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Indesit.
Most Indesit washing machines have hidden filters and are not meant to be customer accessible. If you are referring to the incoming water supply, then in some models, it would be immediately after the connector; if on the other hand, you are referring to the lint/fluff collector/filer, then there is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Indesit W 123 Front Load Washer
Wil133 indesit 1300 washer dryer
look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Feb 25, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine, wil103
from the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
Dec 19, 2007 | Washing Machines
Washing Machine not draining
I have just fixed the same problem. At the front - bottom right is the filter - you may have to remove the kick board on your fitted kitchen to see this - put a small dish under to capture water - unscrew half a turn - drain off all the water - then fully unsrew and pull out - I had money and treads from jeans blocking the filter - clean out, replace filter and fully tighten. My machine worked after this. - Steve
Nov 21, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,639 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
