Need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Need a wiring diagram for an older sony home stero amplifyer
  • Anonymous Dec 11, 2007
    everything works except no sound
    Scholar:
  • 31 Answers
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
Posted on Dec 11, 2007
I need manual for ta-ax 295 system
Try looking here;...elektrotanya.com/sony_ta-ax295_sm.pdf/download.html
Jul 13, 2014 | Office Equipment & Supplies
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
I have a sonyTA-AX-205 and don't know what cables I need to hook it up
google search owners manual. download a copy and refer to the charts.
Mar 31, 2014 | Sony Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
Wiring diagram for a Sony XR-C210 car stero
SONY XR-C210, XR-C214
1-GND
10-+12 VOLT BATTERY WIRE
16-Speaker RF-
5-Speaker RR+
11-+12 VOLT IGNITION WIRE
17-Speaker LF+
6-Speaker RR-
12-Power Antenna Turn On
18-Speaker LF-
8-Speaker LR+
13-TEL MUTE
9-Speaker LR-
15-Speaker RF+
Sep 13, 2009 | Sony Car Audio & Video
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony ta ax 301 has ribbon wire connection from amp to cassette and tuner. The cable was lost when I moved need to know how to make a new cable I have all ready found wire ends but do not know which wire...
Try to locate a mark on each board, see if it has a
dot or # 1 mark. start from that point up to the other end. (it's usaully a straight line pins)
Jun 22, 2009 | Audio Players & Recorders
609 people viewed this question
 Grubhead
Grubhead
