Question about Casio EXILIM Card EX-S770 Digital Camera
Card locked the screen reads "card locked". camera will not allow me to delete pictures
Not sure what kind of card it is but let me talk about SD. If you look at the left side of the disk when the label is facing you and upright, you should see a little slider. In one position it is locked. Slide it to the opposite side and it is UNLOCKED.
Posted on Nov 30, 2007
  • Charles Pedley
    Charles Pedley Nov 30, 2007
    If you look closely, you will see the gray slider on the left side. See above post.
    It is also a good idea to buy a USB card reader just in case the you occasionally cannot seem to get the camera to register with the computer to take your photos off.
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to unlocked memory card?
A locked memory card will not allow you to write to the card; however, you will be able to read from it. Unlocking the card will allow you to delete files and write to the card. You will want to unlock it before inserting into the camera since this will allow you to store folders or files as well as take pictures with your camera.
first you need Look at the sides of your memory card for a tab in a slot.And then Move this tab up or down to put it in line with the icon that is on the card of an unlocked padlock. This unlocks your memory card. You will want to make sure it is always unlocked before using it in your digital camera; otherwise, it will not save your photos.Then you need to Insert the memory card back into your camera after unlocking to start using it to store pictures.Take the memory card out when done.
Move the tab on the memory card back to the closed padlock to re-lock it. This is not mandatory; however, it will ensure that your photos do not get deleted if other people have access to your camera. You can store the card in the camera or the case that came with the memory card.
That it!
Apr 17, 2011 | Cameras
I'd like to delete all the pics on the card, but its not allowing me to.
Check thath the pictures are not 'protected' and the card is not in 'lock'-position. If you're not able to delete the pictures in the camera, use a card reader and delete them in the computer. You can also 'move' the pictures during download instead of just 'copy' them. This will clear the card. Also formatting the card will erase any files on the card.
Aug 05, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Cannot delete photos" Card Protected" appears on screen
There should be a small switch on the memory card that allows users to lock it so no one can delete pictures on it. Take the memory card out of the camera and look for this switch on the card and make sure it is not in the locked position.
May 19, 2009 | Sakar 87492 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Apr 26, 2009 | Pentax *ist D Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
35 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
