Question about Pentax ME Super 35mm SLR Camera
My Pentax Camera Light Meter is not registering changes made to the Aperture Ring.
My camera works fine. All the LED lights light up and the shutters works fine. The main problem is when ever I take a reading, and then change the aperture it still suggest the same shutter speed no matter what f-stop I use.
Example: If I keep the lens at a f-stop of f2 and says 1/500th of a second then change it to f22. It still says 1/500th of a second without saying its under or over exposed.
  • Cameranista Dec 09, 2007
    It seems the problem is the coupler on the camera mainly. Thanks for the help.
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
Take lens off to check the lens/light-meter coupler situated inside the lens mount at the top part of the mount at 'one o'clock' . First see if it moves freely ,clock wise. Then -with the lens off- look through the view finder while you activate the coupler : moving it should make the l.meter lights move up and down.
If you are not getting any joy the connection between the coupler and the board needs re-soldering ( dry joints ) : remove top cover and resolder two blue wires on left hand side of the board . This should do the trick.
Posted on Dec 05, 2007
Pictures are dark
First, check if you're taking the lens cap off. If you're taking it off, then check your exposure. See if your light meter responds to changes in illumination. If everything seems fine, then check if the aperture of the lens works as intended. Then, without a lens nor film in bulb mode, check for the mirror and shutter to work properly. If the light meter, aperture, mirror or shutter seem to flaw, then get your camera serviced by an experienced camera repair technician.
Jan 28, 2014 | Minolta Maxxum 5000 35mm SLR Camera
Bought cheap extention tubes, now camera wont recognize the lens. How do I use them
Set the exposure mode to "M" (Manual). You'll have to set both the aperture and shutter speed yourself.
You'll also get no exposure assistance from the camera's light meter. You can review the picture after taking one and/or use the histogram to tune the exposure.
Sep 30, 2013 | Nikon D5000 Digital Camera
My nikon D5000 does not recognise the new lwns - vivitatar 650 - 1300
This lens does not have the electronics to communicate with the camera, hence the camera does not recognize it. You must switch the camera to Manual exposure mode in order to use this lens. You control the shutter speed and ISO on the camera and the aperture by turning the aperture ring on the lens. You also will not get any metering assistance from the camera. You can use a separate light meter or another lens to get a starting point, then use the playback and its histogram to fine-tune the exposure.
Nov 09, 2010 | Cameras
Nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
Apr 16, 2010 | Nikon F3HP 35mm SLR Camera
Light meter or not on Maxxum 4
Yes, it has program, aperture priority, shutter priority and manual modes.The aperture and shutter settings should be visible on both the right hand top plate LCD panel, and also in an illuminate LED panel below the image in the viewfinder.
From memory (and I might be wrong) the Dynax 4 (Maxxum 4 in North America, Dynax 3 in Asia Pacific) light meter simply indicated a plus or minus symbol to indicate over or under exposure for the selected combination of shutter and aperture. The viewfinder display would have a steady dot to confirm confirm focus follwed by the chosen shutter speed and aperture setting.
I cannot find a link to anything other than a German manual, but the diagrams and a bit of mental application will go a long way if you don't understand German.
Note that if your camera's electronics have failed then there's nothing you can realistically do other than to replace it. Spares are not available and as a consumer level model it was never really intended to be serviced or repaired.
Feb 24, 2010 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
Light meter
Yes, the Pentax ME Super has a built-in light meter. It is used by the ME Super in order to determine the correct exposure settings when the camera is used in the "A" (Autoexposure) & "AV" (Aperture-priority) exposure modes.
I don't mean to insult you, but have you tried new batteries?
Sometimes the meter fails when the batteries don't have enough juice.
Take care & Happy Imaging!
May 17, 2008 | Pentax ME Super 35mm SLR Camera
Light meter
Yes, on the camera body, you have to remove the lens. The ring sits outside the metal mount for the lens.
Feb 20, 2008 | Nikon FG 35mm SLR Camera
Shutter speed and aperture
You can change the settings when you are not using the smiley face setting. Turn camera on press menu go to sensitivity to change film speed, EV compensation to allow more or less light.
Nov 29, 2007 | Pentax Optio S50 Digital Camera
Will a lenses without the A setting on the apeture ring work on a DS
They will - fully open in Av mode, and with any aperture in manual mode - after you allow the Ds through the custom settings menu to use aperture settings different then "A". To choose correct exposure with such a lens in manual mode you can use the AE-button - it stops down the aperture, reads the EV and sets the shutter speed according to the chosen aperture.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax ME Super 35mm SLR Camera Logo
109 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
