Question about EliteGroup FAX 56K CNR MODEM (ECS) (FMCNRB)
E machine T3612 Vista home basic
HELP! I have a 56K ITU v.92 fax modem; system says device and drivers are working properly; however, when I go to fax a document, the print function does not recognize the fax modem as a printer.
0 characters
1 Points
Ive installed win xp on my aspire 4520, but some driver are missing like SM Bus controller,co processor, and 3 base system device. please help
Download the drivers from the Acer WEB site.Make sure you select the model of your laptop and the XP or Vista version ofthe drivers you that require and it matches the Windows version that isinstalled on your laptop. Use this link to get to the Acer support: -
Feb 03, 2011 | Conexant chipset 56K V.92 PCI Data/Fax...
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Modems
Do i need special drivers for xp 64 bit? Broadxent V.92 56K PCI...
Windows XP 64 needs entirely different drivers than Win XP 32, and Windows Vista/7 64bit/32bit.
If you can not find specialized drivers, there is nothing you can do to make it work.
Apr 09, 2010 | Broadxent V.92 56K PCI Data/Fax Modem...
I need fax/answering machine software for 56k us robotics modem
I would go to us robotics website and download the software and driveres for the modem.
Dec 12, 2009 | U.S. Robotics Modem: U.S.Robotics 56K V.92...
Can't install the device driver for SM Bus Controller Have Vista 64 operating system
you will need to find out what make/model mother board you have and download the updated driver.
which model do you have? i can try to help you find it.
Jul 11, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Modem driver
All of you who wanted DLink DFM 562-E's driver, please click the mentioned below:
DLink DFM 562-E (XP)
D Link DFM 562E (Vista)
Thank You
Sep 09, 2008 | D-Link DFM 562E (dfm-562e) Modem
Download drivers...
Respected sir actuly i want to need modem driver intel 56k
Aug 28, 2008 | Intel Chipset 56K V.92 PCI Data/Fax/Voice...
Modem Driver
To download the most appropriate modem driver for your Windows XP computer, a few steps is indispensible to finish the whole process.
Step 1
Look at the modem. Write down the make and model. If you have a dial-up modem in your computer, take the panel on the tower off. Shine the flashlight on the device. On the circuit board, the manufacturer and/or model number is present.
Step 2
Locate an Internet connection. To download Windows XP modem drivers, go to the library or someone's home where the Internet is able to connect. If you have another working modem in your house, you can download them directly to your computer.
Step 3
Go to the manufacturer's official website or a Windows XP modem driver's web page. Windows XP Drivers, Drivers Kit and Driver Support Registry have modem drivers for the Windows XP operating system.
Step 4
Click on the modem device. Select the manufacturer of the modem. Some of the driver sites are XP only, while others are all drivers. You will have the chance to choose your operating system before downloading. Click on the "Download" tab. Wait approximately 10 minutes, depending on the speed of the PC and Internet connection.
Step 5
Burn it to a disk. If you are at another location, you need to burn to CD/DVD for transportation.
Dec 27, 2007 | Smartlink All 56K Modems: V.92 PCI Chipset...
Modems Logo
125 people viewed this question
Top EliteGroup Modems Experts
Brian Sullivan
Brian Sullivan
Are you an EliteGroup Modem Expert? Answer questions, earn points and help others
