Question about Xerox Phaser 8400DP Thermal Printer
I have error 37,002.47
It says call service. The printer was working fine but kept jamming so I shut it off. Now it wont go past that error.
Since my company would rather get rid of it than fix it I am desperate for a solution.
  • Anonymous Jul 29, 2008
    my phaser 8400 says service needed and gives a code 37,002.47. where is the printhead located?
  • wandaejg Mar 24, 2009
    error code 37,002.47:48258
    tried switching outlets, powering up, etc.
    Finally called service-- new print head needed.
    Service call: $150.
    Print head: $860
    Service to replace printhead: $100-150
    If there are any cheaper solutions out there let me know.
    My company wants to replace the printer instead of fixing it.
  • 208 Answers
37,002.47 The Left Jetstack is drawing less power than expected
There is a heating failure in the print head.
The only way to resolve that is to replace the print head.
On of the heaters that keeps the ink melted has opened.
Posted on Dec 14, 2007
  • Rick Kasper Dec 14, 2007
    Here it is from the tech information
      The Left Jetstack is not drawing the expected power from the supply
    Fixed! Did not fix.
    TRY FIRST (Solutions without parts):
    Verify all printhead cables are seated properly.
    Replace printhead.
  • 56 Answers
Hi, the error code you are getting refers to not enough current to power up the printer. I would suggest if you have it on a surge protecter, backups,etc . Disconnect the printer and plug it directly into the wall outlet.
Posted on Dec 03, 2007
Error 37,002,47:118 xerox 8560dn
Error codes starting with 37,002 usually indicates that there is a problem with the printhead (part# 017K04540). This is a major component of the printer and costs around $600 just for the part. If you decide to replace this part, has this item online. Also, here is a video that shows you how to replace it. Good luck, and thanks for using FixYa!
Sep 09, 2011 | Xerox Phaser 8500/DN Printer
My Kodak ESP 7250 has been working fine but suddenly came up with Error code 6202.
Possible ink cartidge level being less.
Open the printer properties to check on the levels. If not remove the printer and connect once again affer shutting down PC.
If this wont work then remove printer, uninstall and reinstall, then connect to check if the printer is detected and installed.
If not drives are jammed/ the main board has errors..
Sep 12, 2010 | Office Equipment & Supplies
Paper jam error nothing appears to be in there.
Kept messing with the printer. Took some of it apart. Changed out cartridge. Still found no jam. Turned it on and off multiple times.
Finally it worked. Prayer is all I know that worked.
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Mar 17, 2009 | Xerox Phaser 8400 Laser Printer
Service required? 37,002,47:198356 error can anyone assist?
37,002.47 The Left Jetstack is drawing less power than expected.
arrwup.gifInitial Action
  • Check the Printhead, Preheater and Ink Loader power connections.
  • If the problem persists, follow the procedure below.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure
Apr 08, 2008 | Xerox Phaser 8550DX Laser Printer
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Cover door open Now paper wont pull down or jams
Sounds like something stuck in paper path, check paper feed area for any obstructions.
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
Xerox Phaser 8400DP Thermal Printer Logo
549 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
