Question about HP LaserJet 2430n Printer
HP LASERJET 2430N
I have a HP 2430N that is having a problem. When I print I get a black faded line on the paper on the left handside. I have replaced the toner and drum and still having problems. Please Help.
  • 56 Answers
Hi, It seems you could be having a fuser problem if the line is running vertical all the way down. In that case you would have to replace the fuser to correct the problem!
Posted on Dec 03, 2007
SOURCE:
HP LaserJet 2430n is not grabbing the paper like it used to
You need to replace either the pickup roller or the separation pad (or, optimally, both at the same time) - both should be removable without tools, they just snap in. You can order new parts at http://partsurfer.hp.com - shouldn't be more than $20 worth of parts. You can help reduce the problem slightly by roughing up the rubber on the pickup roller and the cork on the separation pad by scuffing both with a light grade of sandpaper, just to give it some tooth. But replacing them is best, it'll fix it!
Oct 20, 2009 | HP LaserJet 2430dtn Printer
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
I have installed a new toner in lexmark e120 faded print
I've seen this lots of times with these printers and it usually has one of two causes.
1 the toner settled at one end of the cartridge - take it out turn it iver a few times then re-install.
2 The cartridge just not quite seated in the printer correctly - take it out, and put it back in, making sure that it is fully 'home' at both sides.
The other possibility is a faulty drum unit, but this is far less likely.
Nov 25, 2008 | HP LaserJet 2430n Printer
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
2430N printer
this is usually one of 2 problems either you have a bad toner cartridge (most of the time this is the issue) or you have a bad fuser. if replacing./trying another cart does not fix your problem machine is most likley in need of a fuser.
to replace fuser
remove back cover
Remove the fuser-cable cover by releasing one tab on the cover, and then rotating
the back of the cover toward the center of the printer.
Disconnect two cables at the left, inside, of the printer
Disconnect the fuser cable at the right side of the printer
Remove four screws securing fuser
Tilt the fuser slightly toward the back of the printer, and then slide the fuser out of the back of
the printer.
reverse for reinstall
May 05, 2008 | HP LaserJet 2430n Printer
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 2430n Printer Logo
231 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
