Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Problem for Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Whirlpool window air conditioner 20000 btu's not cooling properly
By tbcox on Aug 15, 2009
My whirlpool window air conditioner 20000 btu's was purchased in 2004. I have less than 1000 square foot house and this unit has previously cooled the entire house but has not done so this season. It is blowing air properly but even when I put it on high and the highest cool which is 7 I am still sweating in the house even in the room with the unit in it...I have cleaned the filter and gotten some leaves out of the vents but still do not have enough cooling......got any suggestions? HELP from over heated.......
Clarification Request
Posted by roniecon on Aug 15, 2009
Hi,I will try and help you,I am Ron.Pull the ac back out,and clean it with a water hose on the inside of the unit,look for blockage on the condenser.Some thing or things could be blocking air from coming threw the condenser coils.You might try using a flash light ,and see if you can see threw the coils pretty good.If you can`t that is your problem.Go to a auto parts and ask for purple power.Read warnings on the purple power label.Put the chemical in a spray bottle full strength.Starting at the top and all the way across,spray a lot of the chemical into and on the coils.Repeat this over and over again for about 10 to 15 minutes. Let it set for about 2 minutes and spray again.Then rinse with water hose(be careful not to bend the coil fins over flat).Use the water hose nozzle in fan like pattern so it won`t bend the fins. Is the evaporator getting cold?(where the filter goes,the radiator looking thing)If the evaporator is not getting cold at all(feel all around the coils,down and up and end to end)If it is geting cool or cold any where on the evaporator,the the freon is low.If it is not cold any where ,it is most likely the compressor gone out.Did you purchase a extended warranty with the ac?If you did you may have caught it in time,the warranty should be at least 5 years parts and labor.If I can help ....roniecon@gmail.com
Solution #1
posted on Aug 15, 2009
Not Rated)
erpaalai
Rank: Guru  Whirlpool Expert
Rating: 91%, 273 votes
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Was this helpful?
Yes
No
Popular Solutions for Whirlpool ACQ158XP
Questions and Unsolved Problems for Whirlpool ACQ158XP
Do you recommend Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner?
Answer
Answer
the passenger floorboard on my daughters Saturn Vue is wet. Could it be a plugged air conditioner... (More)
Answer
I am attempting to remove the front cover so I can clean my unit. I have already removed the screws,... (More)
Answer
The air fan does not work. Can I replace it myself? The compressor turns on but the air does not... (More)
Answer
i have a whirlpool ac it has leaked from somewhere my floor and everything around it is soaking wet... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool ACQ158XP...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
