Question about HP Pavilion dv9013cl Notebook
DV9000 issues My laptop si randomly restarting itself before BIOS. From this point I`ve got two possible cases: 1)either it constantly restarts itself, with no possible way of getting in BIOS. 2) it boots, everything works fine, except WLAN that just dissapared from the sistem. I can`t turn it on, windows doesn`t see it,the led doesn`t change color.I never changed components, nor did I change bios settings.
  • Anonymous Dec 08, 2007
    same problem
I could not get my dv9000 to boot also. I had it under warranty, so I called up HP. They sent me a box, and I shipped it via FedEx (no cost to me since it was still under warranty). I got it back 8 days later. It was a motherboard issue for me, and they had to replace just the motherboard.
They didn't format my hard drives, which I am thankful for. If your laptop is under warranty, I suggest calling HP up and having them fix it.
Posted on Feb 14, 2008
  • 4 Answers
Hey, so ir dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may have hape board ,cpu or power problem ....which can be fixed by repair only.
Posted on Dec 12, 2007
  • sam89007 Dec 12, 2007
    hey, so ur dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may
    have have board ,cpu or power problem
Hp pavillion dv9000 after hitting power button it turns off then on off then on
In case of infinite reboot
- Restart your computer
Wait for your BIOS to display the manufacturer logo or any logo
- T
ap "F8" key immediately: you will reach a list of boot options
Select "Disable automatic restart on system failure
Press "Enter" and wait for your PC to boot.
Jul 18, 2014 | HP Pavillion Dv9000 Laptop/notebook
Alienware x51 random restarts [solved: Dell had the audacity to supply the need with an underpowered PSU for the GPU they offered]
Hello Wiryan =)
Sounds like either a power supply or graphics card issue to me. You could try downloading Almico's speedfan to check your temperatures just to be sure that they are fine.
You should contact Dell, they can probably troubleshoot the issue pretty fast/send a technician to you. The X51 randomly shutting down is a common issue if you check the forums over there. http://en.community.dell.com/owners-club/alienware/f/3746/t/19437557.aspx?PageIndex=1
I assume you have updated every driver to the latest?
Hope this helps! :)
Aug 07, 2013 | Dell Alienware X51 Desktop PC | Core i7 |...
My Dell M70 screen flashes on and off and i have to turn laptop off and restart.
Try a lower resolution like 800X600 to see if it stops. If it does not, the possible issue is the connection between the laptop and the screen. I've had to replace screens for this issue as a last resort and fixes it.
Oct 31, 2012 | Dell Computers & Internet
My acer laptop is automatically restarting plz suggest me how to repair i want to install new XP OS
There are two reasons for computer to get restarted
1 operating system issue
2 hardware issue
to identify the problem
leave your acer laptop on bios screen if it is restarting in the bios screen which means it is a hardware issue however if it doesn't restart in bios it is an operating system issue
To fix xp incert the xp disk, boot the cmputer from cd, in the first screen press enter, then F8 for license agreement and then letter R to repair, the process will take approx. 1 hr and the computer will start working normal
Sep 21, 2011 | Acer Computers & Internet
What is the possible problem when your computer is automatic shutdown while using?
A number of things - all bad.
If I were betting on problems I've experienced, I'd be betting on reasons #5, #6 (memory), or
reason #8 (overheating due to failing fan), unless its reason #3 (virus).
(1) you laptop (if you have a laptop) battery is dying, and the system is hibernating in response to the low power indication.
(2) your computer's "Standby" button is being accidentally pressed (or the button has failed), and the computer is going into "Standby mode" since it thinks that the "Standby" button has just been pressed.
(3) a virus/worm/Trojan horse/spyware or other malware infecting your system can cause a system restart. While your computer is actually up, run an anti-virus scan and let it run until the system
shuts itself down, and keep running these anti-virus scans until it finds something, or the scan
finally runs to completion. Only when malware is eliminated as the cause of your system shutdowns can you proceed to address any other cause(s) of random system restarts/shutdowns.
(4) You're accidentally pressing the system "Reset" or "Power off" button (if you system is a tower).
(5) Your computer has developed a memory error in the area of RAM where the kernel is resident.
(6) Your computer has developed a memory error in the area of RAM where the ROM BIOS is loaded.
In the case of #5, or #6 perform an in-depth system memory diagnostic using your system's
ROM BIOS resident diagnostics. Access these diagnostic programs by entering SETUP while
your system is booting - usually by holding down F2 (or other system-specific function key) while the system is booting.
(7) Other software problem(s)
In this case, boot your system (and use it for awhile) in SAFE MODE. Safe mode is selected by holding down F8 (or other system specific function key). If you system does not randomly restart while in safe mode, then you have a software problem causing the restarts when in "nonSafe mode"
For Windows XP users
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD (Blue Screen of Death). Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
1. From the desktop right-click on My Computer.
2. Click the Properties option.
3. In the System Properties window click the Advanced tab.
4. In Advanced click the Settings button under Startup and Recovery.
5. In the Startup and Recovery window uncheck the Automatically restart check box.
6. Click Ok.
Now if the computer generates an error it should not automatically restart and enable you to display any errors your computer may be experiencing.
(8) Possible Heat related issue
Many computers today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets too hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer. If the CPU fan is starting to fail, the motherboard will shutdown the PC when the CPU
temperature exceeds a CMOS-set threshold, which protects the CPU from a thermal meltdown.
First, verify the fan on the power supply is working by examining the back of the computer and see if the fan is moving and moving smoothly. For all other fans in the computer (e.g. CPU fan and/or
a tower case fan (if you system has one)) you will need to either open the computer and visually verify that all fans are working.
If your BIOS monitors the RPM of the fans enter CMOS Setup and verify it does not report any errors.
(9) Issue with the operating system (operating system bug)
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue (an operating system bug). To help make sure this is the case try the below steps.
1. Reboot the computer and enter CMOS setup as the computer is booting.
2. After you have loaded the computer in CMOS setup let the computer sit for a long time.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall Microsoft Windows - or, since you're running
WinXP Service Pack 2, you may want to simply install (free) Service pack 3 and/or Service Pack 4,
and see if that resolves the operating system bug issue. Note that Windows XP SP2 is a particularly stable version of Windows, and it is unlikely that your "random restart" issue is going to be an operating system bug.
Sep 19, 2011 | Microsoft Windows XP Professional SP2
My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
The issue may be due to any recent hardwrae or software changes and also due to any virus.
1. Remove any recently added hardware/software.
2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
Nov 07, 2010 | Sony VAIO Notebook
HP Pavilion dv9000 laptop computer will not stay powered on and boot up. The Power on and RAM light is lit but the HDD indicator blinks twice and shuts off after 45 seconds. Then the laptop resets and...
Restart the notebook, press F10 and check if you see the BIOS screen or not.
If you see the BIOS screen and if the notebook does not restart in BIOS then this could not be a hardware issue.
But if you do not see the BIOS screen, then perform the steps below :
1. Disconnect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. turn On the notebook and check
If the issue persists then remove and replace the memory modules of the notebook and check it.
If the issue still persists then it could be a hardware issue and your notebook needs to be serviced.
Jun 13, 2010 | HP Pavilion dv9000z Notebook
My hp pavilion dv9000 wireless connection stop
1>> Shut down the computer and then while restarting the computer keep tapping on F10
As you get to the BIOS screen press F9 and then Press F10 to save and exit out of BIOS.
2>>Uninstall the driver from the Device Manager (in control panel) and restart the computer, To install the driver again use the Recovery Manager
Jan 23, 2010 | HP Pavilion dv9000z Notebook
Ibm lenovo R51
have you check the temperature of your laptop. try 2 check on it through your bios. certain features of bios restarts itself when temp is to high to avoid from burning internal components
Feb 16, 2009 | IBM ThinkPad R51 Notebook
PC won't boot
When you can get it to start, go directly into the bios. Once there find hardware monitor. (if your bios supports that). If so, here you can monitor cpu & motherboard tempture. Just let it sit. If its a heat issue you will be able to see it in the bios. Also lets see if the pc restarts by itself. If no restart takes place I would guess this is a software issue. Possible virus/worm. Pull the system memory & reseat. Reinstall windows.
Jan 17, 2008 | Soyo P4I865PE+ DRAGON2 (SFP4I865PE)...
HP Pavilion dv9013cl Notebook Logo
552 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
