Home | Kenmore | 24 in. 17032 Built-in Dishwasher | Water & soap was...
Kenmore 24 in. 17032 Built-in Dishwasher
Problem for Kenmore 24 in. 17032 Built-in Dishwasher
Water & soap was coming out of the dishwaster.
By kbatykefer on Aug 15, 2009
Water & soap was coming out of the dishwaster. Replaced the seal around the door. Ran again on a pots & pan cycle to clean & it worked fine. Ran a normal cycle with dishes & soap & water came flowing out of the bottom now. Any ideas?
Comments:
Aug 16, 2009
- Yes we are using dish washer detergent only.
Aug 16, 2009
- Pots and pans cycle is heavier duty & very hot water. The pots & pans cycle we only had the bottle of cleaning solution in the silverware rack. We are using the same amount of soap. The problem suddenly occured & we do not use a water softener (city water). I tried the float switch & there was stuff in there. It seems to be free moving now. I also found a jar lid stuck in the bottom & removed it. Tried running it again & the bubbles starting coming out of the bottom of the dishwasher. When I ran the clear cycle the bubbles were still left in the bottom of the dishwasher & bubbles came out of the air vent on the sink too. When I stopped the cycles the bubbles looked like they were ready to flow over the bottom lip.
Solution #1
posted on Aug 15, 2009
Not Rated)
drallim
Rank: Guru  Kenmore Expert
Rating: 87%, 682 votes
That sounds like the float switch is acting up. It is a mushroom looking device on the bottom that has a movable (up and down) plastic cup over the top. With the machine off, take the lower tray out and lift up on the cup--you should hear a faint 'click' when it nears the upper limit. It should also drop to the bottom when released. There may be food deposits that interfere with the proper movement of the cup. Are you using dish washer detergent only?
Comments:
Aug 16, 2009
- What is the difference between 'pots and pans' cycle and 'normal' cycle? Do you use more, less, or same amount of soap with each cycle? Did this problem appear suddenly or get worse over time? Do you use a water softener? Open the door during a 'normal' cycle and check for excessive suds and the level of water. If a lot of suds, try a different brand of detergent. If the water is ready to flow over the top of the bottom lip, the float switch is not working correctly.
Aug 16, 2009
- Your recent comments help a lot. It appears that the water pump is pumping AIR as well as water/soap, which explains all the bubbles showing up. Remove the bottom tray and tear the spray arm and everything under it down to the deck. Note the position and orientation of everything as you remove things. There should be a large screen at the bottom which filters solids from the water before being pumped back through the wash--soak the screen in a mixture of white vinegar and hot water for a while to remove water deposits. Also, check the screen for any warping or cracks. When you get down to the pump, start looking for cracked, broken, or warped plastic components and loose or stripped screws. Also, inspect the various water passages for possible plugging. There could be defective gaskets/o-rings in this area. I hope this solves the problem because I'm about out of ideas.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17032 Built-in
Questions and Unsolved Problems for Kenmore 24 in. 17032 Built-in
Do you recommend Kenmore 24 in. 17032 Built-in Dishwasher?
Answer
Answer
Kenmore 17032 Dishwasher is leaking from the middle of the plastic tub and cannot see why
Answer
kenmore 655.13222 k601 bought 5 months ago after insalation machine stops and clean light comes on... (More)
Answer
kenmore 17052 dishwasher flashes the clean button, 7 flashes then pauses and then 7 flashes again
Answer
It leaks out of the float switch, occasionally. I think it comes from the float switch because it... (More)
Answer
how do i undo bottom water sprayer to clear screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 24 in. 17032 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
