Question about X2Gen MG19MY 19" LCD Monitor
Monitor acer al`511 montor tries to come on then color goes bad light stays on green
The color is not correct and I just bought this monitor yesterday what do I do?
Posted on Dec 20, 2007
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
GOOD DAY,I HAVE AN ACER AL 2017 LCD MONITOR,I'VE HAD IT FOR 18MNTHS,AND NOW WHEN I SWITCH IT ON THE ACER SIGN ARE DISPLAYED IN A FLASH AND GONE,LEAVING A BLACK SCREEN,THE LIGHT IN FRONT STAYS GREEN.I'VE...
First place to check will be the bad caps with bulgign top in the power supply section, post back what you see inside so we can guid eyou further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 20, 2010 | Computers & Internet
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
PC starts fine, then the montor blinks and no display. light stays green
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this as it is a common problem I find a lot. Good Luck.
May 24, 2007 | ViewSonic VX900 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
57 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
