Question about ASUS P4P800-MX Motherboard
Asus P4P 800 motherboard no signal on monitor
I am not getting any input on my monitor when I start up my System
  • 84 Answers
Please check at the back of your computer if your are using on board/ and at the same time you have a video card, maybe its hooked up to onboard while it is not enabled since that you have the separate video card. try to unhooked it and put it in the other video slot. see if this will help you out.
have a nice day!!
allen
Posted on Jun 12, 2008
    Genius:
  • 1,601 Answers
Make sure that the right video source is selected in BIOS.
Posted on Dec 01, 2007
  • Thomas Christopher
    Thomas Christopher Dec 01, 2007
    Also, check pins on VGA cable.
'input not supported'
yes it will but u need to adjust it to 1024x 768 60 hertz in settings menu ok
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
I have an Hp a6257c computer and a HP w2207 monitor. It has an Intel processor with 4gb of Ram. My problem: I recently installed 2gb of extra memory and now the computer has a random no start problem. 1. I...
wrong memory
i told you yesterday this
now post is gone!
take out the memory you put in,
the PC now works right,
i also told you the OS will get corrupted files with bad memory
telling you want;?
take out the bad memory (no brand or p/n stated so impossible to help fully)
then reload windows, (refresh , from media files or repair installs)
then post what memory you used
you can not just throw in ANY memory.
most will fail. this old system is very limited on choices too
ask for what works, can do.
but you never once stated the DMM sticks used
brand and full partnumbers.
nor if OS s 32bit or 64bit.
nor stated what OS, windows WHAT? (XP TO 10)
Mar 07, 2017 | HP dx2300 Monitor Personal computer Intel...
I have asus p4p 800 motherboard i dont know about lan driver there is multipal driver
You need to download all the LAN drivers and install one at a time until the correct one works.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 29, 2011 | ASUS P4P800-VM Motherboard
I am using this monitor with our CCTV system, it is not currently displaying the video. As I cycle through the inputs the video image will display for about 3 seconds before disappearing.
Hello there,
ok so if i understand this problem correctly you have a Monitor connected to a DVR for a CCTV System, when cycling through the inputs on the Monitor you find the correct input for the CCTV system but the monitor only stays on this input for a few seconds .
sounds like the input is going out or the Monitor is programed to stay on a single Input, I would try both move the CCTV System to another Input on the Monitor and if that fails see if the Monitor has any Pr-Set settings then you can Default .
if you need any Help with the Default let me know and i hope this information was helpful don't forget to Rate.
Jan 27, 2011 | Bosch MON152CL (Black) 15 inch LCD Monitor
Audio driver of window 7 for asus motherboard model P4P-800 VM
There is no official Sound Drivers for Win7 for your ASUS mobo P4P-800 VM intergrated "Sound Max" drivers.
You can try the workaround to install the drivers to your new OS on your PC from this FORUM SITE.
Good luck.
Sep 21, 2010 | Computers & Internet
I have a brand new computer(no operating system) and I can't get anything to be displayed on the monitor. I can't install the Monitor drivers without the operating system(can I?), and I can't install the...
Every monitor I have seen in the last decade would put a notice on the screen if the input cable is detached. It should say something like "Monitor is working-check cable" or "No input."
Regardless of operating system you wish to install, any of them will choose a basic VGA resolution or at least text, to display the first messages, and if the monitor is working, you should also be able to see the initial text messages from the BIOS.
If you are seeing nothing under any of those mentioned conditions, you may just have a 'DOA' monitor; it happens.
Aug 05, 2010 | LG Computers & Internet
ASUS P4P800-MX Motherboard Logo
281 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
