yes you are right.. the cd which came with the router will not work with mac or vista computers..
don not worry about it, you can do a
manual troubleshooting to fix this problem, i will give you a step by step procedure to fix this problem..try this out ..
To setup your router for a cable modem..
first check..
Connect the Cable modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go
on line,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go
on line wired..
if not your router has to be configured first,
to
config your router
first check this settings..
Configuring TCP/Settings in MAC OS X
Step 1:
Click the Apple icon, select Location, then choose Automatic.
Step 2:
Select Built-in Ethernet under Show.
Step 3:
Click the TCP/IP tab and select Using
DHCP under Configure or Configure IPv4.
Step 4:
Leave the Search domains or Additional search domains fields blank.
Step 5:
Click Apply Now.
You should now be able to access the router’s web-based set up page and configure your router.
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most
Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 4:
When the router’s web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select
Automatic Configuration -
DHCP.and then scroll the page down and click save settings..
Step 5:
Click MAC Address Clone you would find this sub tab at the top in the blue bar.
Step 6:
Select Enable and click Clone Your PC’s MAC.and click save
settings..
Step 7:
Click Status at the to right side ion the black bar
Step 8:
Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you’re not
on-line, perform a power cycle to synchronize the router with the modem.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router’s power cable.
Step 3:
Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem’s lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
Now if you are
on-line wired
remove the cable from the laptop and check for wireless connection
i am sure this would fix your problem in case if you have any more issues revert back to me..
