Sonicview sv-1000 FTA reciever issue
Hi there
i have this sonicview model, was working great but one problem i have,it loads up the latest bin files successfully and reboots by itself, but after rebooting attched with tv, its flashes once, the tv screen goes blank, when i press the front on/off button on reciever, it brings up the screen saying "please wait for the update" and the picture does not come, i have checked everything, switch is okay,downloads of factory bin and latest files all fine, when i select FTA it shows some of the channels but when selected as default FTA/CAS, it says" channels scrambled, the technician says it may be problem due to files these days but my neighbour's systems work fine, any ideas...what could be wrong please. thanks, i am not sure if its the hardware problem..
  • ellajero Dec 07, 2007
    my receiver ia SV-1000 Sonicview, after last bin all I can get is 8888 on display.
    Thank you in advance.
  • 12 Answers
SOURCE: starview digital receiver
Visit they do free diagnostics if you send them your starview cable receiver
Posted on Feb 02, 2008
SOURCE: System constantly re-booting
While this post is very late to answer this question, here is where I found a solution with the DVD still inside. When I used this solution, the whole system reset and worked.
"I had the exact same problem tonight. I put in a DVD and it locked my Toshiba RS-TX20 up. It simply wouldn't respond to anything but unplugging. Then it went into this infinite loop of trying to power up.
I finally got it to boot:
Hold the eject button on the unit continuously while it boots up (be patient!). It didn't open the tray until a couple minutes into the powering up process. After I took out the disc, it booted up normally at the next try.
I am guessing that there's a very small window during the booting process that the dvd drive isn't locked and you have to push the eject button in that small window to get the tray open. Since we don't know when the drive is unlocked, the best bet is to hold down the eject button continuously.
I hope this helps!"
Posted on May 16, 2008
  • 12 Answers
SOURCE: Eurovox Max V 2008 - needs new firmware flash (27 Nov 2008)
go to download the latest firmware its there ive seen it install that problem solved
Posted on Dec 04, 2008
  • 10594 Answers
SOURCE: 32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Posted on Dec 18, 2008
  • 39 Answers
SOURCE: checksum error/defaults loaded
The easiest way to check the battery is to change it out. If you don't have a battery to replace it with, and you do have a multi-meter, you can test the voltage coming from the should be 3v (or very close). If you need help changing the batter, just post your questions.
Posted on Mar 10, 2009
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
Ir code for sat box
Search for LIRC (Linux Infrared Remote Control) on
I found codes for my SonicView SV-1000 there. You can then search download an appropriate text file for your sat box, so that your computer or tablet can beam codes to your set top box. Welcome to http lirc sourceforge net
Mar 17, 2015 | Televison & Video
Missing alot of channels
Try updating your FTA receiver with the latest files/keys.
May 19, 2009 | Ultra (31624) (ULT31624)
Sonicview 360 Elite Dual w/ Dish500dpPLUS EXC! signal cant watch!
You need to use a sonicview splitter and then go into your settings and select proper ports.If you have 2 wires comming from i duel lnb or 2 stats then you install then in the splitter then one wire into your reciever.then you scan the sats on the ports you have them hooked on to. example echostar110 port 1 also tp setting is 12258 Then echostar119 port 2 also tp setting is 12239 then scan. Scan on autoscan. hope i helped :)
Mar 01, 2009 | SMC EZ Switch SMCGS24 24x1000 Mbps
EX1000 codes for TW
Go to a support forum for your FTA reciever and download the latest file. upload it and allow it to configure for the current map call.
Have you ever considered FTA satellite recievers? thousands of channels are avaliable on those. search google for ftasolutions
Nov 28, 2008 | Computers & Internet
FTA updates
how do I get to the up dates on the sonicview 360 premier?
Nov 16, 2008 | Fluke Networks (FTAP-8S) Network...
FTA fix
try autorollbins
Dec 31, 2007 | Televison & Video
SonicView 8000 HD FTA Satellite reveiver,,Info, Literature,Documents
User Manual:
Unfortunately, They do not even have a troubleshooting section it that User Manual, I don't know of a service manual, perhaps loading the factory firmware may clear up your issues.
SV-HD8000 Factory Firmware:
If that doesn't help, try contacting SonicView Directly at:
1-760-884-3171 (Mon-Fri 9AM - 5PM) Not toll-free
Nov 21, 2007 | Televison & Video
102 people viewed this question
