Question about Motorola HDT101 DTV Receiver
Stuck in a loop
It was trying to bring up a channel. There's not enough of a signal but it keeps trying. Meanwhile, it can't be turned off, can't be made to move to another channel, won't bring up the menu or anything. I unpluged it for several days but it's still doing the same thing. The screen is dark and there are flashes across the screen. The red no signal button is on.
  • Darney Dec 02, 2007
    I have the same problem it would seem. Unplugging the unit does nothing.
    It does not respond to any command from the remote control.
    Problem Solver:
  • 7 Answers
Toyem,
I contacted Motorola about this. Sadly, here's their response:
Thank you for choosing Motorola. I apologize for the inconvenience you are having
with your HDT.
I am sorry to inform you that this is a known failure status. If your box is displaying
0000, then it is broken and there is nothing that you can do about it. I apologize
for the inconvenience.
Please contact us if you need further assistance with this matter. You can also
visit our web site at www.motorola.com/broadband to access your user's guide
and frequently asked questions about your product. You can also call us at 1-877-466-8646
option 2 for further assistance.
Sincerely,
Brandon
Motorola Broadband Technical Support
Posted on Dec 03, 2007
SOURCE:
How do I cast on in knitting
Hi I am not a great knitter but I do know how to cast on stitches.
OK here goes, Get your two knitting needles and wrap the wool around both loosely and tie a knot, holding one needle in your Lt. hand and one in your Rt. hand (Rt. needle point is under the Lt. needle point and loop of wool is around both needles)
**take the loose end of wool in right hand and put it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle
YOU HAVE JUST CAST ON 1 STITCH.
Insert the Rt. needle into the stitch you just made and positioned under the Lt. needle***.
Repeat from ** to *** until you have enough stitches.
NOTE to make a firmer row after the first stitch put the Rt. needle behind the complete loop not just the front of the loop.
**taking loose end of the the wool in your Rt. hand , loop it around the point of the Rt. needle towards you while holding every thing firmly, with your Lt. middle finger push the point of the Rt. needle back towards you and at the same time twist the Rt. needle up with your Rt. hand, catching the wool you just looped around the point of the Rt. needle, return Rt. needle back behind Lt. (you now have 1 loop on both the Rt. & Lt. needle) Still holding both needles bring the Lt. needle to the front of the loop on the Rt. needle and slip the loop over onto the Lt. needle ***
Same as previous instructions and keep repeating until you have enough stitches.
Jan 03, 2016 | Crafts & Hobbies
I hooked up an indoor antenna to the TV and select ANT as an input from the menu. Still can't get any channels at all.
First try moving your antenna around (see the sites listed below for the direction to point the antenna to get a signal). If the antenna has an amplifier, try unplugging that unit. (When an amplifier fails, no signal gets transmitted.) Similarly if you have several TVs sharing one antenna, remove the splitter and directly connect the antenna to this Toshiba to make sure that it isn't causing the problem.
You may be in an area where an iindoor antenna may not work for you. Tall buildings and trees can scatter the signal to the point where a digital tuner can't get enough signal to "read" the data. Again use the results from the sites listed below to check what stations are likely to be received in your area.
Different TVs have different tuner sensitivities. An amplifier may help bring in enough signal to get the channels. (Signal loss is inevitable. However, if the signal is sufficiently poor, an amplifier may give you more noise and won't help.)
There are two sources for a site specific list of channels: Antennaweb.org and tvfool.com . Antennaweb assumes an external antenna and is very conservative in the list of channel that you should receive. (It lists two channels from one transmitter in my area.) Tvfool will indicate the channels that you should get with different antennas (indoor, outdoor, amplified signals).
A rare issue can be that the tuner in the TV has failed. The only way to check that is trying the TV with different antennas (or in different areas - one with high signal strength).
I hope this helps.
(ATSC (digital OTA signals) are either enough to read or not. You can't get the fuzzy signal of an edge of range analog signal.)
Aug 15, 2011 | Toshiba REGZA 47HL167 TV
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Jan 19, 2011 | Philips Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
My pc keeps on restarting.
Tap the F8 key when booting up. This brings you to a screen with different options. Choose Use last known good configuration. this should solve the problem. Your system is stuck in a loop.
Please don't forget to rate me.
Feb 02, 2009 | Dell OptiPlex GX280 PC Desktop
Hi, from mexico n800 problem
Are you sure it's the right charger? The charger is not supplying enough "juice" to keep the N800 on when it turns on. Once it turns off, it charges enough to try and turn on again... hence the endless loop of power cycling.
Hope this helps,
Bill
Dec 22, 2008 | Nokia N800
Nhens convertor box www.dsconter.com
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Aug 29, 2008 | Philips Magnavox 20MT133S 20" TV
Input Echo - audio feedback loop
do you record from
a) mic
or
b) line input ?
if a)
turn off your speakers, and use headphones.
or at least turn down the volume, and change the mics position (as far away from speakers as possible)
if b)
dont route the allready recorded channels to your master while recording (-> or mute them)
Feb 09, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Perpetual windows protection error loop!
use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
Oct 20, 2007 | Computers & Internet
Motorola HDT101 DTV Receiver Logo
160 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Dennis Kyne
Dennis Kyne
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
