Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
No water running through the pad
My humidifier is 2yrs old. When I turned it on this year I noticed that there is no water flowing through the pad area. Actually I took off the rubber hose that leads out of the little cylinder where the main water connection goes and there is no water flowing from there either. The humidifier turns on, I can hear the fan but there is no water flow. Any ideas out there as to why??? I tried the honeywell website but the had no information.
  • Anonymous Dec 24, 2007
    selonoid not working
I has same problem and was able to fix ti by taking off the selonoid (cylinder) and then removing both fittings (where the water line enters and then exits the selonoid. The fitting where the water enters has a small pinhole that I found clogged and just cleaned it with a toothpick. After cleaning and reattaching everything, it works fine.
If that doesn't work, you might need a new selonoid which are around $70-$80.
Posted on Dec 08, 2007
  • humanparody Jan 08, 2011
    After installing my "brand new" humidifier I found upon my intial startup that I was not getting any water flow through the filter at all. I could hear(and feel) the solenoid and fan kicking on as they were supposed to so I knew my transformer was putting out power. Luckily I have plumbing experience or else I most likely would have just returned the unit(major hassle if you have already spent hours installing everything). What I found will most likely resolve a lot of peoples' issues that are restarting their system for the season, or unlucky individuals like me who had received a refurbished unit without their knowledge. After confirming that my saddle valve was actually getting water to the solenoid and that the solenoid was actually pulling up on the plunger(which opens the water flow internally, you can hear and feel a "click") I decided to check for blockage in the path of the water through the solenoid like the previous poster. After I removed the solenoid from the housing(leaving wires attached) I was able to unscrew the inlet side from the solenoid. The 1" stainless steel piece your inlet water hose attaches to is actually an inline filter. On one side you can see what looks to be a pin hole. Make sure that looks to be clear. a toothpick is too large to do this, in fact I had a hard time finding a "pin" that would make it into the hole. Once that is cleared, take a pin in the other "open" end and you can use it to slide out the actual filter media from inside the tube. It is a very fine mesh and I can imagine even the cleanest water supply will still leave enough mineral deposits behind over the course of a season to completely clog it shut. Be careful extracting the filter as not to tear the delicate filter mesh. Mine slid out rather easily. Shockingly mine was completely caked in debris, right out of the box even though nothing else in the "new" box seemed to have ever been removed. I was sure that I has not clogged it from my initial startup because I had flushed the hose before I attached it to the solenoid for just that reason. After rinsing the filter thoroughly, looking through the casing to make sure I could see light through the pinhole, I reassembled the unit and blew through it to make sure air was clearing it. I re-installed everything and tried out the unit and everything works wonderfully now. I'd imagine since I am on well water I will most likely have to repat this every season but it only took all of 10 minutes to do.
If i hook my Aprilaire 400 Manual (not auto/digital) humidifier up straight to a 24v wall outlet instead of to the furnace, will it still work correctly? Or does it need to be powered by the furnace to...
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier.
It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
Jan 31, 2013 | Aprilaire 400 Humidifier
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
My desert springs humidifier doesn't work. I suspect that it's about 6 or 7 years old. The furnace is still running and I've tried all solutions that seem obvious to me. Is it possible that the motor has...
Well, let's see what service the unit has had in its 6 or 7 years of working--
When was the Humidifying pad last changed?
These usually have to be changed every year-- to get good performance from the humidifier...
So-- Have you looked inside the large door?-- what does the pad look like?
When the furnace is running, you should be able to open the humidifier door, and look in, (Air should be sucking INTO the door as you open it, if the unit is properly mounted in the return air duct work..) and if the humidistat is calling -- the motor should be turning the big wheel, and moisture is being added, as the wet surface is exposed to the air returning to the furnace. What do you see?
There is also a water sump, filled by a float valve-- is that valve admitting water into the sump?
Is the pad wicking up this water, and rotating into the air stream?
That pad is easily changed-- your hard ware store probably has replacement pads-- they can be sewn back on to the wheel, after removing the old one.
Let us know if we can help further-
Mack B
Jan 15, 2011 | Desert Spring DS3200 Humidifier
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
My honeywell humidifier attachment on my furnace will not start after the summer with water running to it.I have the humidity cranked up, but the filter is still bone dry.
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the sponge...you should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Oct 24, 2009 | Honeywell Power Humidifier: Furnace...
Water and fan won't go on. Is there a way to bypass to see if it works,it is only 5 years old.And if it works how do I find the problem.
Turn the humidistat all the way up. This is the test position that will cause it to run continuously. The blower or furnace must be running, depending on how it is wired. If the humidifier has never been serviced in five years, call a professional. The orifices will plug and pad deteriorates after about a year. These need yearly maintenance to operate correctly.
Oct 03, 2009 | Aprilaire 700 Humidifier
Aprilair 760 Humidfier will not stop water flow to EV panel
If the water continues runs nonstop even when the heater is turned off, you might have either a bad solenoid valve or a bad humidistat. Simply disconnect one of the two low voltage wires going into the unit. If the water turns off then your problem is most likely your humidistat or the low voltage wiring. If the water continues to run even when the low voltage is disconnected you have a defective solenoid valve.
Good luck.......
Apr 09, 2009 | Aprilaire 700 Humidifier
Too much water running through to humidifier
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question,
mr.grzz
Jan 25, 2009 | Honeywell HE220A1019 Whole House...
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
591 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
