Question about Radio Shack Pro-97 Handheld Scanner
Operation problem Only works with charger, will not turn on with batteries.
I had the same problem. the problem is the jack itself, If anyone has ever inserted a plug that is to large it will bend the small tab inside. The correct plug is just a bit smaller. Or else if you use the correct plug but for long periods at a time it can weakin
the tab so that it does not make contact with the center post. The inside tab on the side of the jack must make contact with the center post in order for it to run off of the batteries.
The Solution for this problem ::
TEMP SOLUTION - Is to use a small bent paper clip or jewlers hook to bend the tab back to make contact. however the next time you plug something in it will be the same as before.
THE RIGHT WAY - Is to go to your nearest radio shack and order a replacement
power jack, Its a simple soder conection if you cant do it yourself take it to any respctable elecronic repair shop.
If you want I could do it for you. or help talk you thru it. [email protected]
Posted on Dec 12, 2007
SOURCE:
When plugging in the device the charging light turns yellow, red, green and then shuts off.
If the battery is bad a charger will display whacky operation at times. Could be the battery is so bad the charger simply shuts off after an initial attempt to charge.
Feb 21, 2016 | Health & Beauty
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Tablet wont charge
Apr 01, 2014 | Samsung Tablets & eReaders
I have galexy tab 3 7.0 SM_T210R when it's on standby mode charging normally but when i turn it off it doesn't charging anymore what's the problem??
Apr 01, 2014 | Samsung Galaxy Tab 3 7.0" - White...
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
New Generac Generator--Battery Goes Dead
Yes,if its working correctly,you should be getting a reading about 2.5 to 3 volts above the battery voltage rating while its in standby mode.
Jan 17, 2010 | Kitchen Appliances - Others
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
The laptop powers itself down after only a few minutes of operation. the charger seems to be working and both power and battery lights will show green the laptop is old and i am wondering does it have to...
good or bad. it needsa battery to tun If good then it runs on its own and if bad then support of the charger is required. Can run without the battery too if the charger is present.
Jul 14, 2009 | Computers & Internet
Radio Shack Pro-97 Handheld Scanner Logo
42 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
