SOURCE: What does E000020-0010 error code mean?
e0020 is to do with there not being enough toner in the developer unit.
Firstly it may be a good idea to check/change to toner cartridge.
Switch off and disconnect from mains for the next bit.....
If ok remove the developer roller, cover is above the manual tray on the right hand side then once inside dev unit has connectors at either side, check they are properly seated. If you need to remove the dev there are several black screws around a metal plate all need removing. The roller should be black with toner. May need replacing depending on age and usage of copier.
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Thank you for contacting Fixya.com.
The "E1" error code means the thermistor is open but it could be also a broken wire, loose connections at the teamster and/or the control board and a bad control board.
Please get back to us if you have any further query.
Have a nice day.
