I have a Dell 1704 FPt lcd monitor. When trying to turn it on this morning it never turned on. But the power button started blinking green. The only thing that stops it from blinking green is unplugging it. I took off the front frame in hope that the button got stuck but that did not fix the problem.
The only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Open the C.p.u cover, remove the R.A.M. and clean the Slot where is to be inserted. and also clean the R.A.M. Insert it then see .....
