Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Archos dvr station remote control
Hi guys,connected my tv and sky+ box to the dvr station gen 5 everything is working great but the remote control just will not work.Tried everything sky+codes on the archos player still nothing please,please,please help
  • Fredddyfly Oct 29, 2008
    I have an Archos605 and I have the Satellite receiver and Sky+ box(Thomson make) and I have tried everything opossible to get the "Test Power off codes" to work with no success at all and am at a point of giving up as Archos just says to try another setting.I have the latest Archos software programme installed with apparently all the updated codes.
    If anyone out there can advise, it would be great. Many thanks for lokking at this problem.
  • Fredddyfly May 11, 2010
    As Skicowboys advice, I eventually got the Archos to work. I am still not too sure what I did but I noticed the Sky+ box LED changed from green to red, this being turned off as the same as Skicowboys. It then asked the number of channels the TV had! I cannot decide as to whether it means the TV channels (Freeview) or the Sky+ box. Any advice would be useful as I selected "To buy or not to buy" programme, selecting it to record and instead I got a BBC radio channel!!.
    Any help would be appreciated.
    Fred
It sounds simple, but the archos must be facing the sky+ box. I spent hours messing around with archos support and qvc and in the end it was simple. I put the archos 6" away from the sky+ box, facing it, selected thomson, in the loist of sat receivers and it was code 15 of 16, good luck.
Adrian
Posted on Feb 11, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 THIS DOES WORK BUT DVR FACE SKY BOX TO GET BEST OPERATION.
Posted on Feb 05, 2009
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
Posted on Dec 25, 2008
SOURCE:
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
No sound when I record from my TV
Are you using the DVR Station Gen 5 or DVR Travel Adapter?
Jan 23, 2008 | Archos 605 WiFi Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Mar 25, 2008 | Archos 605 WiFi Digital Media Player
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
1,039 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
