Question about Toshiba G 7 Multimedia Projector
Toshiba tlp651u projector
When the projector is turned on the lamp lights. After a few seconds the lamp goes out and the led lights on the machine turn red. The owner's manual mentions to change bulb or call service. I have changed the bulb but no change in operation of the projector. I have contacted several service providers in the area but they are unsure of the problem. (no toshiba service centers near my residence). Does anyone have a probable cause for this malfunction?
  • Lloyd Bond
    Lloyd Bond May 11, 2008
    I too have the exact same problem...I have the Toshiba TLP-470A and i purchased a new bulb,but the light comes on and goes back out after a few seconds. LED turns red for on and lamp. After about a minute, it returns back to amber or stanby and is ready to turn on again.
    I too have dropped it off to a certified Toshiba service center and they could not locate the problem...they said try a different bulb...I returned the first bulb as deffective and received a help, It does exactly the same thing....can someone please help if you know whats wrong
The small 3x3 cm blower might not run.
Posted on Nov 04, 2008
When you install a new bulb you have to reset the bulb timer it tells you when the hours are up. hope this helps
Posted on Apr 28, 2009
VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
Jun 27, 2012 | Sony VPL-HS50 LCD Projector
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
I have the model TLP WX 2200 and doesn't turn on and after a few minutes, the ON led is green, is blindnig and a bip is heard. After a while, the two of three leds ( on and lamp ) are getting red. What...
It seems lamp is dead/ broken in projector, please check lamp and replace it to fix the problem.
There is lamp cover at bottom side of projector, remove lamp cover to take out lamp.
Detailed procedure of lamp replacement is written in user manual page-45
Click Toshiba Support link to download user manual free copy, if required.
Nov 10, 2010 | Toshiba TLP-WX100U LCD MOBILE PROJ WXGA...
After replacing the lamp in the projector Toshiba TW300, it shall then appear on the screen saver, and then after a few seconds off. then it beeps and lit LEDs ON and LAMP. How to fix this problem? lamp is...
1. check the lamp and the rating for this unit it may not have the proper rating for the DLP and is shutting down to protect the circuit.
You may not have the right lamp installed.
Feb 09, 2010 | Toshiba TDP-TW300U Multimedia Projector
I have the same issue minus the clicking
check the lamp for bulges, black spots, or fogging. if that's ok, check the colorwheel. if that doesn't spin, the lamp won't light. if they are ok, replace the ballast.
Sep 30, 2009 | InFocus SP-LAMP-LP3F Projector Lamp for...
Unit turning off after displaying red pc chip icon
Hi whitiezn
If you say that this unit is very new , it should on all accounts still be under warranty.
Contact your local Toshiba Service Centre and have this problem sorted out on their account - the machine should still be under warranty.
May 05, 2008 | Toshiba TLP-ET1 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Toshiba G 7 Multimedia Projector Logo
257 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
