Question about iLO 2600 Television
Color is messed up on 42" ILO LG HD
We received the TV as a gift, we did not receive a hand book I have tried locate a manual and cannot fin anything on the internet. The color has never been set correctly, We have no greens and no reds help!!! I can't seem to find anyone to come out and look at it.
I own a 26inch, I may not see a Green and Red option but if you have the remote you can select TV MENU; from there you can use the down arrow to the bottom portion and you can also choose to do a factory reset if that helps. Otherwise at the top part theres a way to customize all; brightness, saturation, etc under picture choose Custom
Posted on Dec 01, 2007
SOURCE:
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
HOW TO CONNECT MY ILO TO MY DISH NETWORK AND MY TV
Hi Calvin Graham, the answer will depend on if you have a HDTV and receiver or not. If the model # on the front of the receiver starts with ViP, then it is an HD receiver and the picture will be on HDMI1. If not a ViP, it is SD and I would try AVideo1 input on the TV. Also if not an HD receiver and the TV is in the room with the receiver you can try channels 3 or 4. If the receiver is in another room try channel 60 or 73 on the TV. Feel free to contact me with any questions.
Mark Haakenson
Internet Response Team
DISH Network LLC
[email protected]
Dec 13, 2011 | iLO DVDR04
Having green or red "static like" issues with my
The color wheel is messed up, cant be fixed, try calling the help number
Dec 12, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
HEllo I purchased the 42 plasma and was wondering
Go to this site and get the correct manual
http://www.lge.com/products/sidemenu/list/plasma%20tv_PRD|MANU_manu.jhtml
Note you have to be able to get an HD signal for the TV to display it. If you are on satellite TV, then a new receiver is needed.
Oct 20, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
LG hdtv lcd wont turn on will only go to blue screen
How old is the set.. If you its relatively close to being out of warranty LG will probably cover the repair. Contact them at 800-243-0000.
Dec 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Programing codes
If it's not listed you can't. This doesn't stop you from hooking the amp up to the tv.
May 20, 2008 | Denon AVR-1907 Receiver
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
107 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
