Question about Hitachi 43FDX01B TV
Red power light comes on and no picture
We moved our tv. It was working properly before the move. we did not have long enough cord to hook it up right away. When we got around to hook it back up, The red power light would come on and no picture at all. Not even a screen for a menu. We tried switching cables and tvs. Our Hitachi won't even make a snow sound or picture. Is it worth taking in to be fixed? If you know what the problem is.
Thanks!
  • charleywaite Jan 05, 2008
    53fdxo1b horizontal output is shorted q777 and pico protect fuse is open e905 3k pico is flyback bad or regulator series pass breaking down under load
    Genius:
  • 1,694 Answers
Sometimes after a move,a bad solder connection causes a
part failure,maybe just a fuse device....have it checked by a
qualified technician.............T.
Posted on Jan 06, 2008
SOURCE:
I just bought a Hitachi rear projection tv off craigslist. Tv worked fine, I gently transported to get it home, plugged it in and for nothing. The red light comes on and it sounds like its trying to come...
no matter how careful you going to be moving it something is going to come lose. may even be a bad soldering joint and it come away completely. you will need to check the power board very carefully looking for somthing that dont look right. also this can happen in transit the outer case for the bulb housing may have moved away from the switch that would make the tv not turn on at all as it needs to be pushed in. take the cover of it and then put back on locating the switch you will see the switch when the cover for the buld is removed..
Oct 22, 2013 | Hitachi Televison & Video
Our dryer model wed6200sw1 will not power up. my brother inlaw installed a 3 wire power cord when helping us move. there is a white wire that hangs loose in the housing that I believe is a nuetral ground,...
This is tough to say without being their.. But lets try...You need to hook up the power cord correctly before doing any other diagnostics...On the dryers terminal block you should have a black on one side, white in the center, and red on the other side THE POWER CORD WIRES HAVE TO BE HOOKED UP THIS WAY. when checking voltage at the back of unit make sure its 120 volts from center to right side , and 120 volts from center to left side after this is correct we can diagnosis from their if its not working right.......
Sep 01, 2010 | Dryers
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Brand new roper dryer, was working fine, moved it to a different house, had to change from 3 wire to 4 wire cord, now it runs but no heat. have 110 on black, 110 on red, all components ohm good
the wires may not be hooked up right. make sure the red goes to red, black to black, white to white.and the green one screwed to the groung screw.
i have had this problem where all the components check out good and the power was correct,and the unit would still not heat,the end problem was the wiring from the main breaker box was incorrect and not carrying enough current to operate the machine properly.you may have to have the wiring check for proper current flow.the voltage maybe good but the amps and current may not be porper.
if you have a electric stove with the same kind of cord you can move the range out and plug your dryer in there just to check the operation of the dryer.
Jan 26, 2010 | Roper RES7646KQ Electric Dryer
Protron lcd tv getting no power
I have the same problem. I am told that I need a new power supply (adaptor) but from what I am reading on the Net, they are very rare and TV repairman told me he cannot find the part. I heard that Protron is out of business.
Jun 03, 2009 | Protron PLTV-32 Television
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Samsung hl-r4667w needs power cord reset to turn on
How much was it moved? It could have jiggled something loose or made an intermittent connection, try removing the bulb/lamp and put it back in to reseat it, it might be detecting a lamp issue due to a bad connection, or a lamp thats starting to fail, if you have a spare lamp you can try replacing it. If thats not it then it may just be something is failing due to age/heat in the tv and moving it caused enough shock to the part to go intermittent. Most commonly when a projection tv does this its a problem with the lamp, or the power supply board.
Jan 02, 2018 | Samsung HL-R4667W Rear Projection...
Hitachi 43FDX01B TV Logo
132 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
