Question about NetGear WGR614 Wireless Router
Router help!!!!!!!!!!!!! i cant't get the router to work,when i try to type in 192.168.1.1 on the other computer it says not hooked to the internet and do you want to work offline,also shows page not displayed .what do i do to get the inernet on my 2nd computer
    Problem Solver:
  • 10 Answers
Hi, is your second pc wired using the ethernet cable or wireless?its better if you use an ethernet cable to your 2nd pc. you said that its not pulling the 192.168.1.1, you have to check the ip address on the pc first because if your pc wont show it then it means that its not detecting your router.
ex: for win xp/vista
start-->run-->type cmd press enter-->you'll see a black screen, type all lower case ipconfig then enter. you should see there default gateway either for lan or wireless that matched the 192.168.1.1. if it does, try going to safemode by restarting pc while tapping f8,choose safemode with networking n try launching it there in your ie, if you dont see the num then troubleshooting needs to be done for you to get the correct nums..its best also if you contact your isp..i hope this helps.
Posted on Dec 02, 2007
Verizon modem to dynex router to hook up sprint airave.. and nothing is working I did all the set up but cant type in ip address with no internet.. HELP!
Have you tried typing in 192.168.0.1? Or 192,168.1.1?
If so, what happens when you do? One of those addresses should take you to the configuration screen for your router, at which point you should be able to configure your router and go from there.
-a.
Jun 02, 2010 | Dynex 4-Port Ethernet Broadband Router...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Computer can't find the router
Configure your router first, by doing that you need a ethernet cable (cat 5 will do). Connect your computer to your router using ethernet cable and open internet explorer, type in the ip address of your router and press enter. After that, you will be ask for username and password, just key in your username and password (if you cant remember, reset your router and key in the default username and password of your router). Once your done, go to internet setup and you can configure everything there. Hope it helps you.
Jun 21, 2009 | Dell Wireless 2350 Router
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in 192.168.0.1 and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Trying to get online but cant
You have to make sure that the router isn't still loading, to unload it you need to hook the internet to a local computer in your house. Just get on any website and then hook it up to your PS3 and it should work.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
When I set up the router It comes back with the internet is not hook up, but when I hook the intern et up to the lap top it goes right through Please help me with this problem
try restarting the modem while it is connected to the router. the modem probably thinks that it is hooked straight up to a computer not a router. if that doesn't work go to the web gui by going to the routers ip address on a computer connected to the router. the easiest way to find its ip is to go to run (or the bottom search bar if in vista) and type in cmd. once this is up type in ipconfig /all look for the the default gateway. write this number down somewere.
next go get on a web browser (internet exploiter or fire fox) and in the address bar type in that number. this will take you to the web gui. start adjusting the router so that it works with your internet service.
Aug 14, 2008 | Computers & Internet
Limited or no conectivity
hello!
-- are you connected hardwired or wirelessly to the router?
-- do you have other computer working on your network?
-- what is the operating system of your computer?
May 06, 2008 | Linksys Wireless-G WRT54G Router
Cannot complete downloads
when you say that everything works when the router is NOT hooked up to the PC, does that mean that you have the DSL modem connected directly to the computer?
then, when you hook up the router, you're connecting it BETWEEN the DSL modem and your computer?
You probably need to log in to your router and set it up to connect through the DSL modem to the internet: it may not do it automatically.
is this computer running windows XP?
if so, go to control panel, then network connections.
if you double click on the local area connection, and go to the support tab, it should list something like this:
Address type: assigned by DHCP
IP address: 10.0.1.100
Default gateway: 10.0.1.1
Try opening internet explorer, and typing in the numbers it lists for default gateway.  hopefully, that will bring up the configuration screen for your router.
Mar 26, 2008 | Computers & Internet
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
