Question about Samsung SGH-D500 Cellular Phone
Java games i have a samsung d500 and it wont let me go into my java games. if i press select on downloads it goes to go in but goes straight back to the java menu. can any one help please. thank you.
  • Anonymous Mar 13, 2014
    it does not download whatsapp and java games please help
    President:
  • 1,017 Answers
If you select downloads, your phone will try to connect to the Wap (Internet) service. If you haven't set it up with the settings to go online it wont work.
Settings are sent to you through a text message by your service provider.
Posted on Dec 27, 2007
SOURCE:
Tip
How To Install Java Apps & Games In Samsung Star S5230 & S5230W ,Etc
Follow the step by step tutorial as follows to install external third party java games in your Samsung star cellphone.
Samsung Star S5230 & STar Wi Fi: How To Install Java Apps & Games1.First download a java game compatible for your phone.
2.Create a jad file using JADMaker Download JadMaker
3.Just drag and drop your .jar file and the jad maker will automatically make the .jad file.
4. Connect the phone to PC and start “Samsung New PC Studio”. Open the File browser and go to “External Memory”. Create a directory there e.g games
Then copy the .jar and .jad files into that folder.
6.Disconnect the phone from PC now.
7. Go to Menu -> Browse -> Enter URL
Type -> http://m.GetJar.com
8 .Browse down and you will see “Quick Download”it. Then enter quick download code as 51799 . Download and install it.Exit from browser.
9. Go to Menu -> Applications -> Games and more -> LiteFTP
You will be in LiteFTP menu, Select Mmc (Memory card) and click OK.
11.You should be able to see the folders in memorycard. Select games folder (dont enter it) and press “123′ button. Thenpress “1′ (This will copy the game folder). Select “Back”. You shouldbe back in “root” directory.
12.n root directory you will see a folder with do not enter symbol named “My PrivateMy PhotoMy Video …….”. Select it and press OK to enter it.
13.There will be nothing in the folder. Now paste the game folder. So press “3′ to paste.
Exit the LiteFTP.
14. Open “Keypad” and type *#6984125*#
This will automatically open “Admin setting”
Select “4 Internals” and enter *#9072641*# , And confirm.
This will take you to “Internals” menu.
Select “6 Storage settings”.
15. Select “2 Update media database”
then select “3 Update Java DB”
then select “10 Create Ax Dat File”
Exit from all those menus.
16.Now you have to go to Menu -> Applications -> “Games and more” You should be able to see new icon “LiteFTP/files/Erix”.
Rename it if you want to.
And you can enjoy your games in the same folder. Have fun & do comment if any problem occurs.
(plese rate me)
on Mar 08, 2010 | Cell Phones
I could not able to transfer java based games to my mobile
Hai,
For Samsung D500 tutorial CLICK HERE Just make sure you use this enable Serial Java download code *#52828378#.
Hope this Helped!
Aug 26, 2009 | Samsung SGH-D500 Cellular Phone
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
I HAVE SAMSUNG E1410 MODEL. CAN I DOWNLOAD JAR. OR JAD. FILE TO MY MOBILE????/
for installing java games n apps,first in the main screen,dial a no...."*#9998*4678255#.
then put the java app's jar n jad file in "other files" folder of the memory card n pres the center(play/pause) button to open it.
Jun 11, 2009 | Samsung SGH-D500 Cellular Phone
How do i download java applications to my phone
for that, u need to download the java games to your PC first.
after that connect to your PC through data cable or bluetooth.
start the samsung application loader software.
and rest u ll understand on your own.
thanks
Mar 20, 2008 | Samsung SGH-D820 Cellular Phone
Samsung d500
I googled for u and found this link
try this... this gives a detailed procedure for doing it.. i dont know whether it gives a legal method or not... but worth visiting the page
http://www.noeman.org/gsm/samsung/21826-samsung-d500-installing-java-games-applications-via-bluetooth.html
Have a nice day
Feb 12, 2008 | Samsung SGH-D500 Cellular Phone
Mobil
Hi there mate
I had the exact same problem go to google and search up uploading java games to samsung d500 you need to download the softick tool and the ppp for samsung d500 thats the application my solution search google theres a site thats give you the exact details and the sites to download the exact software your after hope this helps an if you have the time please rate me that would be great
thanks again
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Oct 15, 2007 | Samsung SGH-E900 Cellular Phone
Samsung d500 problem with downloading hava applications
Check if java script is enabled and also u must try upgrading the browser if issue continues.
Mar 01, 2007 | Samsung ZX10, E315, E317, P735, E630, D500...
Samsung SGH-D500 Cellular Phone Logo
78 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
