Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printing power point slides
I am in university and my prof posts power point slides each week. Many students are able to print the slides 6/page/ They simply select file, print, print what, handouts,6 slides/page. I do not have those options whan I click file or print. I have a hp all in one 6210, can you help
When you click File, Print, you should see a "Print What" on the dialog box that pops up to the lower left. You want to select "Handouts" and then there is where your fellow classmates are selecting 6 to a page... You can also select if you want to print vertically or horizontally and up to 9 slides.
Posted on Jan 10, 2008
SOURCE:
Following a printing job of more than two or three pages, both orange lights and both green lights come on. The printer then is not functional. There is no paper jam. If I turn it off, then back on, it...
I had this problem at work. We went from a PCL 6 driver to a Universal PCL 5 driver and it worked fine printing multiple pages. And has ever since. I would check your driver first and see if it can be updated. If so, update it and try again. If not or updating doesn't work, try a different driver, especially if you are using a PCL 6 on a 32-bit or an XP machine. Best of luck to you.
Aug 04, 2011 | HP LaserJet 4L Printer
It will not print. It passes the paper through without printing anything on it. The ink cartridges are new. It prints a test page. but it will not copy. The computer says its ready to print. The...
A test page prints with the proper ink/text showing up?Have you tried restarting the computer? Have you powered off the printer and turned it back on? You could try reinstalling the printer software and see if that helps.
Mar 21, 2011 | Dell 948 All-In-One InkJet Printer
I'm trying to print of slides for a lecture - when I click "print" on powerpoint, I change the number of slides per page to 3, click frame slides, and click two-sided printing. When I click okay...
I hate to ask, but do you have a duplex printing module on your home printer or are you printing from a printer that has two sided printing capabilities?
Feb 07, 2011 | Computers & Internet
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
[email protected]
May 27, 2010 | HP Laserjet Cp2025n Printer
HP Officejet Pro L7680 When printing a power point presentation, lines are printing over the jpeg pictures on the slide
There is some problem with your print heads. Run a print diagnostic report and see if it helps. You also may want to trigger clean cartridges if triggering print diagnostic page does not help.
This issue may happen if the printer is not used for few days. Recommend to keep the printer powered on always, or then trigger print diagnostic page as it tries to unclog the blocked print heads to give you a clean print.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to print more than one power point slide per page
select print and when the printing window appears to choose printer then single click on your printer and click on "Printing Preferences" . In tab "Layout" you'll then see the option "pages per sheet" (if your printer driver support it). Select the number of pages you want to print on a single sheet. and finally click ok.
Sep 10, 2009 | Microsoft PowerPoint 2000 for PC
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Black ink not printing
Same problem. Will print web pages in color, diagnostics work, but will only print photos in black.
Jan 19, 2008 | Epson Stylus 880 InkJet Color Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
105 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
