Question about HP Officejet 5610 All-In-One InkJet Printer
Cartrdge Jam Hi theres a problem with my printer. For some reason the cartriges wont move. It keeps telling me to remove any paper jams but theres not paper jams in the printer. I can visibly see the cartriges when its time to print and it just looks like something is holding it back but I cant see what it is. Please help.
  • Anonymous May 05, 2008
    The paper jammed in printer. When I removed the paper there is a small piece still stuck in it.
  • 12 Answers
I would like to provide you a weblink of a document which is related to the issue that you are experiencing which would help you in this regard.
Here is the weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&cc=us&lc=en&dlc=en&product=441125&dlc=en&lang=en
Please revert me with the results..
With regards,
Ashesburn.
Posted on Feb 25, 2008
Epson Artisan 835. Just set up. Printed fine. Tried to eject DVD/CD tray. Did not eject. I turned off unit. Turned back on. Now constantly says I have a paper jam when there is none. Cannot use.
Hi. I Have an Epson printer too and become to send the paper jam error when there not a paper jam on the printer. Check the ink cartrige bay with the printer off. The ink cartrige bay have to stay all the way to the right. If not push carefully to the right. Start again the printer and see what happens. This cause in certain ocassions the paper jam error. I hope this tip can help.
Aug 13, 2013 | Office Equipment & Supplies
My Toshiba E-studio 650 keeps E03 which means paper jam how can I fix this?
Probably moved some sensor caused by the paper jam, the sensor looks out of place or dirty and also check the continuity of the cables.
Apr 24, 2012 | Office Equipment & Supplies
I keep getting error message C000 which tells me to shut down the printer and restart it. How do I fix this. Thanks
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Jan 29, 2011 | Canon Office Equipment & Supplies
Error C000!! what can i do it wont print,
  • Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
  • If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
  • Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Sep 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
The printer says there is a paper jam. I have
Try adjusting your paper tray. If you have the tray that adjusts from legal to letter it sometimes gets wiggled to some place inbetween. Just push it back into the letter position.
Apr 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Carriage jam issues on hp printer
So sorry to hear that you are having issues with your C4385 printer. HP's All-In-One printers seem to be very touchy when it comes to carriage jams, and mine is no exception. They are usually caused by little bits of paper left over from a previous jam, so you just have to work out where to find them. HP produced a page with diagrams to help people find them. Please click here to access their solution page.
Hope this helps!
Nov 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer is totally jammed
check whether any paper is jammed you can remove the jammed paper from the back of the printer .there is a assess door which can be easily removed and from there you can check if there is any paper jam and you can remove.if there is no paper jam and you still face the problem.it is necessary to open the printer and service the parts and oil the gears to make the printer move fluently.you can do it your self if you have proper screw driver it does not require any thing execpt a proper screw driver to disassemble the printer.or you can take it to any proper service center and it will work properly after it is serviced.
Sep 05, 2008 | HP DeskJet F380 All-In-One Printer
Paper jam
well..you may need to remove the software, and re install it...
and also, unplug the printer for around 5 min
May 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
