Question about Toasters
Ariza xtreme satilite reciver
I cant figure out how to program the codes into my ariza xtreme reciver
0 characters
1 Points
Toaster sticks in down position and won't shut off until pushed up. Seems to be gummy in there but I can't figure out how to get to the mechanism to clean it. Any ideas?
The name of the game is to remove the outer cover so you can while the unit is unplugged observe the mechanism and locate the area that is full of gunk and jamming it up. If absolutely no screws anywhere then unit has snap on parts and you have to pull them apart.
It was put together by man - it can be taken apart.
Aug 06, 2015 | Toasters
I need to buy a new chain drive. How do I know how many links I need?
Youcan use a chain length calculator to figure out how many links you need foryour chain, drive. Click this link to read more information and download a calculator
Jul 17, 2012 | Franklin Machine Products CHAIN, DRIVE 55...
I can't figure out how it goes back together. The toaster lever wasn't working, so my wife took out the crumb tray and turned the toster upside down thing something was jammed. A long metal rod and long...
That long rod and spring sound like the rod that the opperating lever rides on, kind of a guide, the spring is what pops it up when the toast is done .. should be sitting verticle in a groove or hole in the opperating lever.
Jun 02, 2010 | Cuisinart CPT-70 Classic Style 2-Slice...
I am reassembling my sunbeam AT-W. Cannot figure
If you mean a serpentine channel that serves as a strain relief for the cord, (with the appliance upside down on a stable surface) try just a bit of fresh electrical tape to hold it in place while you ease down the base on it; check just before it meets, that the wire hasn't moved (and nothing else is getting pinched!), and hold it down while you get the first screw back into it to keep it. Then put the rest of them back in and once they are all well started, snug them all down. Test outside on a dry, fireproof surface, from a GFI outlet for safety.
Oct 10, 2009 | Toasters
Toast rack won't stay down, and I can't figure out how to get inside to look at it.
Simple, hold it down all the way, for at least 3 to 5 minutes, with nothing in it.  Then release it, and try it again.  It should work.
Jul 28, 2009 | Sunbeam 3802 Toast Logic 2-Slice Toaster
I need the user manual for Hamilton Beach toaster model 24600
you can download a user manual from this site,
click on the link or copy and paste link into a browser and on the site look for the download manual link, click on that to download a user manual, save it to your desktop to either print or just to read, this manual is a PDF file, if you do not have the program then you need to download a pdf program first from here and install it following the onscreen instructions after downloading.
Jul 28, 2009 | Hamilton Beach 24600 4-Slice Toaster
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift #20 toast "wires"
May 04, 2009 | Toasters
Bread toaster doesnt work
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
Aug 29, 2008 | Back to Basics TEM-500 Egg & Muffin...
My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
May 29, 2008 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Toasters Logo
47 people viewed this question
Top Toasters Experts
Mike Cairns
Mike Cairns
Are you a Toaster Expert? Answer questions, earn points and help others
