Question about Samsung SGH-t629 Cellular Phone
Cell pjone water damage
How do I dry out a cell phone with water damage (no salt water).
  • 1 more comment
  • jesefont Jan 14, 2008
    my daughter put my phone in the dogs water and i blew dried it and it now only comes on for a quick second. i am gonna try what you did and hopefully i can still use it tomorrow.
  • lwill67 Jan 29, 2008
    a drink got spilled on my phone, but it didnt stop working that night, the next day it started showing low baterry & then went off. i took battery out and let the phone air dry, it then came back on, but then it went back off after about 30 minutes, saying low battery , even though i had been tryin to charge it all day, it wouldnt keep a charge. do i need a new battery or is this signs of water damage.
  • Anonymous Mar 19, 2014
    the cell phone was in water for a couple of seconds,taken out and dried off. it won't start now even after recharging
That will not work in a lot of cases if the phone is of a newer model. i have an lg prada with water damage and it was completly un-successful. the only way i have found is to buy a repair kit from ebay that comes with a liquid that removes all water and residue from the phones main microprosesor. this will require u to take the phone apart and remove the microprosesor/main board.
go on ebay and look for water damage repair and is should come up, it is an american company.
Posted on Mar 13, 2008
    Problem Solver:
  • 15 Answers
Turn your phone off for at least a day. Dry off your phone if you haven't already. Take out the battery, dry out the inside of the phone. If you have a sim card, take that out and leave to dry. Leave the battery out of the phone for a day as well. Put it back together after a day and try to power it on. If it doesn't come on, try plugging it in without the battery in. If it works that way, you simply need a new battery.
If this doesn't work you're probably going to have to get a new phone. Your cell phone provider will be able to tell if it's water damaged, so check with them to see if they replace water damaged phones.
Posted on Nov 30, 2007
SOURCE:
I have one maxwest cellphone it's damaged by water, can it fix it?
Open the phone and remove the battery. Dab all internal surfaces with paper towel to remove as much moister as possible. Then use a hair dryer on medium heat to gently dry the phone completely. Make sure the battery is dry as well. Leave the phone open for a further half hour after drying and then put the battery back in and close the case. Switch on the phone, good luck.
Dec 30, 2014 | Cell Phones
Tip
If your cell phone gets into water...
Two differents situations can occur when you drop your cell phone in water: depends if it is salt water (beach) or fresh water (rain, etc). I use to repair cell phones for 6 years, and this is my best recommendation.
If the phone gets into fresh water, just remove the battery immediately, because the battery normally creates a short circuit inside the phone, then try without battery and if you can remove part of the housing, do it and put a small fan or a hair blower ( not too hot) aside the phone at least for 15 minutes continue, moving around constantly. This has to be done immediately, because the minerals in some types of water can cause bridges between the IC (integrated circuits), and cause malfunctions.
If the phone gets into salt water, and this include if you drop it into the toilet while urinating (remember, the urine if full in chemicals, most of them are salts), although it sounds crazy, just immediately remove the battery, and give a fresh water wash, I mean, try to wash all the salt from the phone, and then start doing the process to dry it as described before.
Two tips more: It is probably that your battery will damage permanently, and nothing can be done. And, this not guarantee that the phone will work, because it depends on how long it was soaked. In a next opportunity, I can give you a little higher difficult level to do in order to completely recover your phone from future problems due to water damage.
on Dec 29, 2009 | Cell Phones
Water damage
If this was salt watercor contaminated water, then the only chance is to immediately remove the battery and rinse the Phone several times in clean pure water to remove the conductive salt / contaminated water. Then leave it to dry out in the sun or in a warm place for a few hours until all the residual moisture evaporates & drys out. With any luck the phone will turn on and work. If it was left with salt water or contaminated water for a long period before rinsing this may lead to permanent internal damage.
Nov 01, 2013 | Motorola Mobility MOTO W755 Cellular Phone
I dropped my samsung in my sink and i picked it up and took out the battery and let it dry and about 30 mins after i put the battery back in and up comes a blank white screen and it keeps vibrating how can...
Once a phone has been water damaged it will never work properly again. Water - even fresh water - contains salt. And, salt is an excellent conductor of electricity. When the water evaporates, salt deposits still remain. This causes the phone's electronics to short circuit causing a variety of problems.
The cost to repair the phone will far outweigh the cost to replace it. Repairing it does not mean that it will continue to work properly.
My advice is to sell the phone on eBay for parts. Let the buyer know it has suffered water damage. And, replace it with a new phone. You'll be much happier in the long run.
Feb 16, 2011 | Samsung SCH-U450 Cell Phone
Hi, I dropped my mobile SGH-F210 in the water. As soon as it happened I opened and let it to dry. It was working for a few hours but it stopped working. At first it was showing that the battery needed...
Unfortunately, all water - even fresh water - contains salt. And, salt is a very good conductor of electricity.
When cell phones get wet, trace amounts of salt will collect and then dry on the phone's circuit board causing circuits on the board to 'short out'.
We use to repair cell phones with water damage here at the shop. Many times, they would begin to work again - only to become very problematic a few days later.
Keep in mind, even if you pay for your phone to be repaired, chances are it will not stay trouble free for very long.
Your best bet is to replace it. It's better than wasting good money on a phone you'll soon need to replace anyway.
Jan 26, 2011 | Cell Phones
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
I droped my N70 in WATER...
remove battery, if not done already, let it dry, at least for days. drying faster, if you can open it somehow...
i hope fresh water, salt water means it will die whatever you try as the salt will destroy the circuit boards after some days.
Nov 25, 2010 | Nokia N70 Cellular Phone
My Samsung Solstice (a887) cell phone recently spent some quality time in the washer. I removed the battery and sim card, put it in a small container with rice and exposed it to low, radiant heat for 3-4...
The problem that you currently have is not the water damage but the damage caused by the salt that has gotten into the phone. Specifically, water is not a conductor of electricity (though everybody thinks that it is). It is the salt in the water that actually conducts electricity. And, the salt from your clothing was removed by the water in your washer and deposited into your phone. (It only takes just a little bit of salt to conduct electricity.)
Now that the water is gone from your phone, the salt remains inside it. And, there is no way to remove it from the phone's circuit board.
Long story short - even it your phone began working correctly today, there is no guarantee it would continue to work the same tomorrow.
Bottom line: Go get a new phone. You'll be glad that you did in the long run.
Feb 01, 2010 | Cell Phones
Unfortunately it may be too late...the phone should have been turned off the battery should be taken out as soon as it was taken out of the water...this keeps circuits from shorting out...
BUT...it never hurts to try everything...
Place the phone in a sealed container full of uncooked rice, and leave it there for at LEAST 3 days...thats 72 hours of not powering it up...as tempting as it is to "check"
You have to give the rice time to draw out any moisture.
Hope this helps.
Jan 14, 2008 | Motorola Mobility RAZR V3
My phone in salt water.
To anyone who drops their phone in salt water. Get the battery out immediately. When you get home or sooner if you can put the phone in something that will allow fresh water to immerse it entirely. Keep water running in the container for about 3 days continually flushing the phone. Now take all of the water out and fill the container with 99% Isopropyl Alcohol. Let the phone dry out for at least 2-weeks before trying a fully charged battery in it and turn it on. Should work and you have just saved yourself buying a new one. Then don't leave it in your pocket when you go to the beach, drop it in a Ferry Salt Water Toilet, etc., where it it is immersed in salt water. If it is most cell phone providers will refuse to even look at it from their tech depts. A Radio Tech/Inspector in Canada.
Dec 22, 2006 | Motorola Mobility V600
Samsung SGH-t629 Cellular Phone Logo
333 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
