Apple iPod nano 3rd Generation Logo
Posted on Aug 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen froze on cover flow. nothing now works.
Was listening to a song, scrolled on cover flow to select a new song before the curretn one was done, and the screen has frozen. It won't power down, recharge or anything.
Josh Levin
Level 2:
  • Expert 75 Answers
  • Posted on Aug 15, 2009
Josh Levin
Expert
Level 2:
Answers
75
Questions
Helped
17785
Points
201
If u hold down the center button and the play/pause button at the same time the ipod will restart. Trust me I had the same issue before on my 30GB Ipod Video
6th gen. nano has shuffle issues. plays same song over and over
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
1helpful
My ipod touch will not play in shuffle mode plays a couple of tracks then stops
you might have reset to shuffle again
4helpful
2answers
Froze and won't come back on
Try connecting it to a computer if nothing Remove the back and check and see if the battery isn't fully connected push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screenand memory, Black screen Blue ring problem) and put the back on.Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
84helpful
8answers
Can't create playlists on my zen x fi
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
2answers
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
3answers
Sansa e200 froze
hold the menu button for about 15 sec. and it'll turn off
I can turn my sandisk player on but its stuck...
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
2answers
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
When i burnt music onto my MP3 something happened!!!!!!
Nellbell you still having problems with this unit.
You Might try
Copying and deleating all songs on player then load 1 song and try
Reformat the unit and try again
Update firmware from Samsung site.
Try reset button (Under color cover use a pin)
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
