Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker not getting water
I have a whirlpool side by side with water and ice dispenser in the door. I get water through the door but the ice machine is not producing any ice. I do not think the water line is fozen as I could get a straw up the dispenser without obstruction. What is my next step? Thank you.
  • 1 more comment
  • 2057 Dec 09, 2007
    I also have a side-by-side... water comes out just fine, but the ice maker isn't making any ice. Had a similar problem a year ago, where the water supply tube, inside the freezer, froze up, therefore no water would flow into the ice tray. Doens't seem to be the same problem this time. Any thoughts?
  • Anonymous Mar 22, 2008
    Ice maker is not working. No water getting to the ice maker. Have replaced the ice maker, and solenoid valves. What's next? It's not plugged or frozen. Also replaced filter. Water gets to door for dispensor Is there a reset for the ice maker????
  • jnbk8424 Sep 30, 2008
    We replaced the water filter a month ago. the water to the door works, the ice machine runs, but doesn't produce any ice. we are confused?!
Check to insure that the water line going to the ice maker is fot frozen. If it is use a hair dyer in the cool mode to melt the ice in the line.
Posted on Feb 13, 2008
It could be the water valve at rear.check water supply to valve,
if that's ok,you could change valve at rear
Posted on Dec 04, 2007
Thanks... well, had Sears come out and look @ it. As it turns out, this time, for me, it was the actual ice maker itself- not the water line. As the repair man said, "It's not 'if' the ice make will break... it's just when." Aparently, these things are just going to fail. The repair man said he has a two-year old refrigerator and the ice machine failed. He said the only way to avoid this is 1) get the extended warranty; 2) don't buy a refrigerator with an ice maker/dispenser. Aparently, the parts just wear out. Well, I ended up getting a whole new refrigerator. Since my last posting, the refrigerator door hinge on the top failed, also. The plastic, that these rocket-scientist used, when desiging the Whirlpool Gold side-by-sides (with the curved top doors and fronts) is a weak spot... other than that, it's a good machine. A new refrigerator door: $1,060. I payed $1,064 for the unit 4 years ago. Now, I've got a KitchenAid with flat (metal) surfaces around the hindges... and I got the warranty for when the ice maker goes out!!! Time will tell.....
2 Suggested Answers
SOURCE:
  • 126 Answers
SOURCE: Ice maker not getting water
check your water valve you have 2 located at lower back of refrig.
Posted on Dec 11, 2007
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The in-door water stopped working. The ice maker still gets water, but there is no water coming out of the door dispenser.
You more than likely have a bad water valve. Unfortunately, the water valve is a double valve ,one side services the ice maker,the other side the water dispenser.Even though the ice maker is getting water the whole valve has to be replaced. Hope this helps
Jul 30, 2009 | Whirlpool ED2GHEXN Side by Side...
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
326 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
