Question about Kenmore 61042 Top Freezer Refrigerator
98 kenmore refrigerator
Icemaker is only making 4 cubes of ice. It is taking for ever to do that. Do you have any suggestions on what to do or if there is anything?
Someone told me to check water line & to see if filter is clean but, I don't know where to start looking?
SOURCE: Dirty water out of dispenser
Spoke with Sears help line. They said I need to replace my water line. I'm going to look into replacing it myself. I'll let you know how it goes.
Posted on Feb 22, 2008
SOURCE: Kenmore side by side frig with icemaker
The water smells funny and taste moldy/musty. Where is the filter to change it? I've looked inside and out and can't find it.
Posted on Jul 24, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
  • 738 Answers
SOURCE: Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Posted on Mar 27, 2009
  • 738 Answers
SOURCE: kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Posted on Apr 08, 2009
SOURCE: Model 363-9534753 Kenmore icemaker not dispensing ice cubes
I had the same issue and here's what I did to fix it. I pulled out my ice bin. Pushed the metal rod that's underneath it up. Pushed it back into place so that the metal rod would go above the lever in the hole in the back. Sorry- don't know any of the technical terms or names of parts, but once I readjusted the position of the rod I got ice cubes. Hope it works for you!
Posted on Apr 28, 2009
0 characters
1 Points
How to fix a kenmore ice maker leaking water
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Feb 20, 2015 | Kenmore Refrigerators
Can ice maker be adjusted to make more ice on a kenmore coldspot
No. The icemaking capability is set by the evaporator temperature. Check the condenser is clean and clear
Apr 21, 2012 | Refrigerators
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
How do I turn on the ice maker and water??
You will have to find the faucet which controls this 1/4" line. It may be behind the fridge, or in the basement if you have one. Once you turn on the water and get it running just put the wire control arm, located right above the ice cube bin, into the doown position.
It generally takes about 24 hours to get your first batch of cubes.
Aug 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side 253.54662400 makes hollow ice cubes - do not dump
yes i would replace the icemaker. it sounds like the heater and ejectors have lost their sync. could be caused by the internal drive motor.
Jun 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Kenmore 61042 Top Freezer Refrigerator Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
