I have the Sub Zero 650. I am not sure if yours iworks same but what you do is use a 3/32 Allen wrench; as you push the handle into the screw on the door so that it is flush, you insert the Allen wrench in the hole at the bottom of the short vertical connector at top and tighten; repeat for upper or lower part of handle.
Black pan below refrig is filling up and overflowing with water; what should I do to minimize the...
(More)
Black pan below refrig is filling up and overflowing with water; what should I do to minimize the problem? Do I need to do anything with the lines on the inside back of the regrig?
the refrigerator is not working. the temperature is at 60 degrees even though I have the temperature...
(More)
the refrigerator is not working. the temperature is at 60 degrees even though I have the temperature set to 34 degrees.
