Question about Motorola DCP-501 Receiver
DVD player doesnt work...wont open or anything
I bought the DCP501 used. When I first hooked it up the DVD function would work and say reading disc or no disc. the feeder tray would not open and i couldnt select the dvd setup options on the main menu. i then heard a grinding type noise and now the dvd function doesnt do anything at all, no display, nothing. anyway to fix this?
2 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: DVD Player won't work
DVD's: does it display any kind of error? All DVD's?
To your second question.
The manual explains cable and TV hookup for CABLE but there is no mention of off-air TV tuning.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Posted on Apr 28, 2009
I bought a new LG Blu-ray player at Best Buy in December of 2009. For the last couple of months (begining in May of 2010) I'be started experiencing my player not wanting to play a large majority of my...
two of the main problems associated with players are their motor's and their lens. the lens emitts a light which reads the image off the disc, if the lens is going bad then that lighting signal isnt as strong as it should b and it wont be able to read the disc. on the other hand if the motor spinning the disc is spinning to slowly or it starts but doesnt continue spinning to allow the lens to read the disc then u will experience the problems that u are facing with your player.
solution: get the whole lens motor mechanism changed.
Aug 26, 2010 | LG BD370 BLU RAY PLAYER
My dvd recorder will play but not burn anything at all
your laser lens of the dvd doesnt work thats why it doesnt read the disc the same thing was happening to me so u can open it and look if the thing where the laser lens is at is not stuck or your lens they wont work anymore.
Apr 30, 2010 | Cyberhome DVR 1600 DVD Recorder
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
In SONY CD/DVD Player, it is able to read CD where as DVD is not able to be read. Saying NO disc. What could be possible reason and remedy for the same.
Some dvd have a multiple laser function for dvd and use a single laser for cd. common fault on not reading dvd is dirt on laser or fault on multiple laser that cannot read dvd. If cleaning doesnt help only repair tech can fix. Just check that the dvd is working in another dvd player to ensure it is not disk
Aug 14, 2009 | Sony Televison & Video
Portable dvd player - wont play
Hi
Bought a dvd laser lens cleaner for 10 euro played it through the dvd player a couple of times and its working great now
thanks.
Apr 08, 2008 | Televison & Video
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Dvd player not working
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
Sep 10, 2007 | Toshiba SD-4900 DVD Player
Motorola DCP-501 Receiver Logo
35 people viewed this question
Top Motorola Audio Players & Recorders Experts
Nidhish Ganga
Nidhish Ganga
Jeff Tilburn
Jeff Tilburn
ray gallant
ray gallant
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
