Question about NHJ Limited VHD-5100 (5 GB) MP3 Player
VHD-5100 (5G) MP3 PLAYER PC conection problem
When I connect the player to the pc it displays connecting and the pc sounds like when a device is connected and then sounds like when is disconnected. But the screen is still connecting
SOURCE: battery NHJ VHD-5100 (5G) MP3 PLAYER.
Try going to Ebay and buying a battery for the Handspring Treo 300. They are very inexpensive. The battery is about the same size. The connector is a little bit different but seems to fit OK. The Treo 300 battery has been working in my VHD-5100 for about a year now.
Posted on Dec 09, 2007
0 characters
1 Points
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this will help you.
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
I can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
  • When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
  • Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
  • The player does not appear in My Computer.
  • Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
  • When you use the player on another PC or laptop, it works flawlessly.
  • Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
  • Go to, enter in the model u have in the search area and then go to support, this should fix the problem!
May 28, 2010 | Samsung YP-U2JZW MP3 Player
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Mar 20, 2009 | Archos Internet Media Tablet MP3 Player
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
System is not searching the player
ok.i have the solution for you...go to CONTROL PANEL after to DEVICE MANAGER but keep your device conected ,,it will detect your device like herror just delete it and desconect your device and conect it again and follow the steps..good luck.
Nov 14, 2008 | SanDisk Sansa e200 MP3 Player
Connect to pc
Sounds like the system files have been corrupted or deleted.
The HDD6330 is only compatible with Windows XP (With Service Pack 2) & Windows Media Player 10. If you have version 11, you will need to uninstall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the player to the power supply and PC.
If the player is recognised by the PC, select the repair/restore option in Philips Device Manager, and follow the on-screen prompts.
This will format the player and re-load the firmware.
If this doesn't help, then post details of what happens, and I'll try to help further.
May 10, 2008 | Philips GoGear HDD6330 MP3 Player
Unableto connect to PC
You have to have Windows Media Player version 10 or higher, if you do not then the device will not install correctly.
If this does not apply, then check the Device Manager for errors while the device is connected. If you see any RED or YELLOW errors listed, right click on them and select un-install.
Disconnect the device and re-connect it to install the drivers.
If that doesnt work, add to the message and we can go from there.
Best of Luck.
Please RATE my solution BELOW.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
Connect to PC and use device manager to repair
If you have the software conect the device to the computer; press volumen + with on/off switch at same time; then press volumen - anh hold it. The software recognice the device and you can update the firmware or repair it.
Aug 20, 2007 | Philips GoGear HDD6330 MP3 Player
NHJ Limited VHD-5100 (5 GB) MP3 Player Logo
41 people viewed this question
Top NHJ Limited MP3 & Digital Media Players Experts
Are you a NHJ Limited MP3 and Digital Media Player Expert? Answer questions, earn points and help others
