Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel (NZ) tumbler dryer
Buzzer sounds continuously at switch on,no lights on control panel, no response from any buttons
  • grantah Nov 20, 2008
    I have the same problem buzzer just sounds and nothing lights up.
  • EHL1 Jan 02, 2009
    Dryer just emits a continuos tone when plugged in. The machine won't power up.
Try switching off the power to the machine for 5-15 mins and then re-switch power on
Had same symptoms with my multi-temp F&P front load dryer.
Andy
Posted on Feb 11, 2008
SOURCE:
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: [email protected]
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Aug 21, 2017 | Fisher Refrigerators
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Fisher gw511 paykel
it sounds like a motor control board fault, needs replacing. in NZ re-con unit about $130-140
Jun 19, 2013 | Fisher and Paykel GWL11 Top Load Washer
How do I turn the beeper off on my Fisher & Paykel auto clothes dryer
From what I see unfortanetly no..is the short answer, they utilize it for warnings in their system as well. You could try contacting them directly, but after reading all their dryer manuals http://www.fisherpaykel.co.nz/customercare/userguide/index.cfm I could not find any way to do so. I will continue to look for a way however this is what I am seeing currently.
Dec 27, 2011 | Dryers
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
The control panel is non responsive. SOME LIGHTS ARE ON AND SOME LIGHTS ARE OFF.
If you remove the control console, there is a pretty decent diagnostic sheet packed inside. It should be on the left side all folded up. Generally, if power cycling the unit doesn't have any effect, a new control is warranted
Apr 19, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
287 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
jimorris77
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
